Template help - Should be easy fix
Thread began 9/22/2009 1:17 pm by dlcjonathan389671 | Last modified 9/23/2009 3:01 pm by Eric Mittman | 749 views | 2 replies |
dlcjonathan389671
When i post this javascript in my dreamweaver template when i go to update it it delates the script and replaces it with the bottom part. If i don't post the scrip its fine but image rollovers wont work.
function MM_swapImage() { //v3.0
var i,j=0,x,a=MM_swapImage.arguments; document.MM_sr=new Array; for(i=0;i<(a.length-2);i+=3)
if ((x=MM_findObj(a[i]))!=null){document.MM_sr[j++]=x; if(!x.oSrc) x.oSrc=x.src; x.src=a[i+2];}
</script>
Replace the above script with below text
<!-- InstanceBeginEditable name="head" --><!-- InstanceEndEditable --></head><!-- InstanceEnd --></html>
&lt;!--
//--&gt;
<html xmlns="http://www.w3.org/1999/xhtml"><!-- InstanceBegin template="/Templates/Untitled-3.dwt" codeOutsideHTMLIsLocked="false" --><head><!-- InstanceBeginEditable name="head" -->
dlcjonathan389671
this is the whole head section of the template if it helps
<head>
<meta http-equiv="Content-Type" content="text/html; charset=UTF-8" />
<!-- TemplateBeginEditable name="doctitle" -->
<title>Untitled Document</title>
<!-- TemplateEndEditable -->
<link href="../main_new_layout.css" rel="stylesheet" type="text/css">
<link href="../main_content_colum.css" rel="stylesheet" type="text/css">
</script>
var gaJsHost = (("https:" == document.location.protocol) ? "https://ssl." : "http://www.");
document.write(unescape("%3Cscript src='plugins/" + gaJsHost + "google-analytics.com/ga.js' type='text/javascript'%3E%3C/script%3E"));
</script>
try {
var pageTracker = _gat._getTracker("UA-10238859-1");
pageTracker._trackPageview();
} catch(err) {}</script>
<style type="text/css">
.style2 { text-align: center;
color: #AFAFAF;
line-height: 18px;
.style4 { color: #FFA73F;
.style5 { color: #BFE90A;
body {
background-image: url(../backgroundbrownn.jpg);
</style>
<!-- TemplateBeginEditable name="head" -->
</head>
It looks as though your code is being encoded with the html entities. It looks like you also have the code in the script tag inside of an html comment. You should try removing the comment from the code so it is more like this:
// the rest of the code in here
</script>
If you continue to have problems with this post back with the exact steps you are taking that get you this result, there may be a problem with the way it is being added in.
