PowerStore SSL Checkout
Thread began 6/24/2009 7:06 pm by jasonkline326722 | Last modified 10/21/2009 10:23 am by Ray Borduin | 6700 views | 9 replies |
jasonkline326722
I am ready to go live with my PowerStore. How do I configure the PowerStore checkout process to use SSL encryption? I tried changing the following code in cart.php:
//WA eCart Redirect Check Out
if (isset($_POST["WA_Store_Cart_Checkout"]) || isset($_POST["WA_Store_Cart_Checkout_x"])) {
$Redirect_redirStr="checkout.php";
********** change to *********
$Redirect_redirStr="https://mydomain.com/store/checkout.php";
This works but keeps you in SSL encryption mode until you close the browser.
Right... when would you like to go out of ssl encryption? At that point send them back just like you got them there in the first place this time using . You control when and where you send someone to and from your ssl site by specifying it in the link.
warrenphillips25336771Beta Tester
where and when
how do you do that then ray? and where?
Any time you specify a redirect page or have a link to another page you have the opportunity to change to or from an https:// location. When would you like to return someone to the http:// version? On the receipt page? Linking from the receipt page?
That is where you would update the navigation.
morc.mzw383871
How to Redirect Entire Store to "https://"
How do we redirect the entire powerstore from "http://" to "https://"?
I tried changing it in the WA_Global.php (to "https://")but when I click on my website "www.xyz.com", it still show .
Please advise. Thank you
When do you want to?
Always? A mod rewrite in your .htaccess might be the best route:
RewriteEngine On
RewriteCond %{SERVER_PORT} !^443$
RewriteRule ^/(.*) https://%{SERVER_NAME}/$1 [L,R]
or you could probably add code to your globals file to do it with php like:
if($_SERVER['HTTPS'] != 'on'){
$url = "https://".$_SERVER['HTTP_HOST'].$_SERVER['PHP_SELF'];
header("location: ".$url);
morc.mzw383871
How to render the entire site secured!
1. How do we implement option (a), e.g. create the .htaccess file?
2. How do we implement option (b), global files? I wrote those lines in the WA_Globals.php and upload the file. The error message is "Parse error: syntax error, unexpected '{' in D:\Hosting\3905780\html\WA_Globals\WA_Globals.php on line 13"
3. Which option is optimal/better?
Thank you. Please advise.
Here is a tutorial I found that talks about .htaccess:
htaccess/
Are you sure you copied the code I gave correctly? It sounds like you missed something... post lines 1-13 of that file here and I can try to spot the problem.
3) mod-rewrite is probably better, but it is 6 of one and half a dozen of the other. It is worth investigating the mod-rewrite concept, so maybe number 1 is worth doing for the experience alone. 2 is probably easier, so really it is up to you.
morc.mzw383871
Secure site
1. Tried .htaccess method but to no avail.
2. The code line 1-15:
$WAGLOBAL_Root_URL = "http://www.xxxxxx.com/" ;
$WAGLOBAL_Site_Name = "xxxxxxx" ;
$WAGLOBAL_Address = "xxxxx Center Blvd";
$WAGLOBAL_City = "New York City";
$WAGLOBAL_State = "NY";
$WAGLOBAL_Zip = "11109";
$WAGLOBAL_Country = "US";
$WAGLOBAL_GoogleAPIKey = "ABQIAAAAbrDo7RkoC8-w_3CWMPTV4BSOJpghMGQ8yTCQ5uInKAzgbZ0gmhTzjWM_GcEQp7saeZe5JstiKJChcw";
$WAGLOBAL_localRoot = "/NurtureStore/";
$WAGLOBAL_remoteRoot = "/";
redirect($url);
Is there anything wrong with the code?
instead of:
redirect($url);
it should be:
and you should probably update:
to:
$WAGLOBAL_Root_URL = "https://www.xxxxxx.com/" ;
