Powerstore(4) Galleries - HTTPS?
Thread began 12/03/2010 3:19 am by info405361 | Last modified 12/10/2010 8:14 am by Jason Byrnes | 2989 views | 8 replies |
info405361
Hi All
I have powerstore 4 installed and all was fine untill I installed an SSL Cert and now operate the site in HTTPS
Everything still seams to work except for the galleries we have included into some product descriptions. The gallery box shows but with no pictures.
I have check my plesk setting and I have the site runing using the same directory for both ssl and non ssl
Any ideas most welcome
Kinds
Roger
in the galleries/global.php file, try changing:
$Root_URL = ((isset($_SERVER['SERVER_PROTOCOL']) && strpos($_SERVER['SERVER_PROTOCOL'], 'HTTPS') !== false) ? 'https://' : 'http://') . $_SERVER['SERVER_NAME'] . ( (isset($_SERVER['SERVER_PORT'])&& $_SERVER['SERVER_PORT'] != 80)?":".$_SERVER['SERVER_PORT']:"") . $assumedRoot;
to:
$Root_URL = 'https://'. $_SERVER['SERVER_NAME'] . $assumedRoot;
info405361
Sorry Jason, that did not make any difference any other thoughts?
info405361
Bump
Bumped, I realy at a loss on this, any ideas?
can you send a link to where i can see the problem please.
info405361
products_detail.php?ProductID=3
the same change needs to be made in the mediarss.php file.
change line 33:
$WAGLOBAL_Root_URL = ((isset($_SERVER['SERVER_PROTOCOL']) && strpos($_SERVER['SERVER_PROTOCOL'], 'HTTPS') !== false) ? 'https://' : 'http://') . $_SERVER['SERVER_NAME'] .( (isset($_SERVER['SERVER_PORT'])&& $_SERVER['SERVER_PORT'] != 80)?":".$_SERVER['SERVER_PORT']:"") . $assumedRoot;
to:
$WAGLOBAL_Root_URL = 'https://' . $_SERVER['SERVER_NAME'] . $assumedRoot;
info405361
Thank you
Hi Jason,
Thank you, this has solved my problem and the gallery is now working correctly in https
Merry Xmas
glad to hear it is working.
