Side menu categories
Thread began 2/03/2010 10:28 am by paul.urgero235355 | Last modified 2/05/2010 5:08 pm by paul.urgero235355 | 2102 views | 7 replies |
Paul
The site I'm doing is for a company that has about 16 categories, but almost 500 products. So obviously, if someone clicks on any of the Product\category links, they are going to see hundreds of products listed on the left sidebar.
How do I have the categories on the side menu become collapsible? In other words, only show the categories on the left, or the category requested and their corresponding products?
Make sense?
Thanks for your help...
Paul
muddysmurf
I was just about to post a question about this too.. and I was going to add on another complex question.
John_GR
would also like a reply on this...
It takes a fair bit of hand coding to make this happen, it is not a simple edit and is not supported.
You have to edit the CSSMenuWriter/intermediate.php file to dynamically create a spry accordion for each category
In the intermediate.php file, there are two loops, the first loop displays each category, use this loop to create the spry accordion. The second loop shows all the items in that category, use this loop within the collapsible frame.
If you are comfortable with the Spry Frame work and hand coding PHP, this should not be to difficult.
Just FYI, this is a feature we hope to offer in PowerStore V3
Paul
Jason,
I understand that this is a feature you "hope" to offer in V3...but if upgrading to V3 is anything like upgrading to V2, it is a fresh installation then. I just did that from V1 to v2. Is V3 going to be a clean install?
Also, since this is not part of V2, can you or someone create the intermediate.php page and offer it to us? Or at least the first category that we can copy and paste sort of?
How am I supposed to tell the client that he's stuck with 300-400 products streaming down the left side of the page?
<intentional suckup here> C'mon Jason, I know you to be a very nice guy, who spent 3 hours 1 day on the phone with me until the problem was fixed. Can you help all of us out here and write it up for us?
Paul
Yes, the update to PowerStore 3 will be a clean install, mostly because the database structure has been changed to offer new futures such as subcategories.
In reality, the functionality you are asking for is not a supported feature of PowerStore 2, it will be supported by PowerStore 3.
I am more than will to go the extra mile if you are having trouble implementing a supported feature of the products we offer. What you are asking for, goes beyond the scope of support, you are asking for free custom development.
If you are not happy with the products being listed on side, you can always remove that code so that it only displays the categories.
the code to remove from the intermediate.php is:
<ul >
  <?php do { ?>
      <?php if ($totalRows_ProductMenu 0) { // Show if recordset not empty ?>
  <li><span><a href="<?php echo($assumedRoot); ?>Products_Detail.php?ProductID=<?php echo $row_ProductMenu['ProductID']; ?>"><?php print $row_ProductMenu['ProductName']; ?></a></span></li>
  <?php // Show if recordset not empty ?>
} while ($row_ProductMenu mysql_fetch_assoc($ProductMenu)); ?></ul>
Paul
Actually, Jason...that worked fine. Having the categories only on the left side bar works better.
Thanks again for your help!
Paul
Paul
If anyone is able to create the spry accordions and would like to share their handiwork, please post it here! :)
