Error Message opening EM CSS Sculptor
Thread began 5/07/2009 9:47 pm by donegan365577 | Last modified 6/09/2009 9:21 am by jon_upton195465 | 5715 views | 10 replies |
donegan365577
I downloaded the new version of EM CSS Sculptor today and installed it.
When I opened Dreamweaver CS3 to access CSS Scuptor I received the error message
I have attached to this message.
I have tried disabling, uninstalling and reinstalling but that does not work. I still get the same error message.
In addition, I have tried to go back to an eariler version, again that does not work.
I would appreciate any help in this matter.
I will be posting a message to the WebAssist Trouble Desk but I would prefer not to have to wait 48 hours for help.
Sheila
buonsen368464
Error message when opening CSS Sculptor
Yesterday, I downloaded an updated version of CSS Sculptor (version 2.03) and installed it. While trying to open DW CS4, an error message appears that read:
The following JavaScript error(s) occured:
Unable to open script file "C:\Program files\Adobe\Adobe Dreamweaver CS4\Configuration\shared\WebAssist\CSSSculptor\Library\WA_configuration.js" (error 3)
I later disable the CSS Scultor from the Extension Manager and enable it again. I then tried to open DW CS4, the same message appeared. The CSS Sculptor 2.03 from DW CS4 window cannot open at all. Can someone help me?
Ozdachs
version 2.03ersion 2.03 is gone
I went to the website this morning in response to yesterday's email announcing the update. Version 2.03 is not available to download, and the system shows 2.0.1 as the latest version.
Joe Lowery
I just double-checked and it's definitely 2.03. Could you check again?
Best - Joe
donegan365577
Problem Solved
Hi Everyone,
I just wanted to let you all know that my problem has been solved.
I posted a Trouble Ticket early this morning, 8 May 2009.
I received a message from Jason Byrnes, at 02:13 PM on 8 May 2009 suggesting I try deleting the WinFilecache-########.dat
It worked. I am back in business.
BTW, I checked my download folder and CSS Sculptor 2.0.3 was still listed early this morning.
Thanks again and have a great weekend everyone.
Sheila
larsentim278054
I got the same error you did, but I'm on a mac. I can't find that file you had to delete. What should I do?
Originally Said By: donegan365577
  Hi Everyone,
Sheila
The file still exists on the mac... it is just named MacFilecache-#######.dat
Where are you looking for the file. It should be in the user configuration folder where extensions are installed.
Mac OSX;
-DW8
--Hard disk: Users: <Your User Name>: Library: Application Support: Macromedia: Dreamweaver 8:Configuration
-DWCS3
--Hard disk: Users: <Your User Name>: Library: Application Support: Adobe: Dreamweaver 9: Configuration
-DWCS4
--Hard disk: Users: <Your User Name>: Library: Application Support: Adobe: Dreamweaver CS4: en_US: Configuration
jon_upton195465
Dreamweaver CS4 on Vista
I have the same problem as Sheila where is this wincache file?
I did a search but cannot find it
open windows explorer
Type: %appdata% for the path and press return
from there browse to "Application Data/Dreamweaver CS4/en_us/Configuration and you should find the file there. Make sure dreamweaver is shut down before deleting the file.
jon_upton195465
Up and running now
