How to remove my custom presets
How do you remove custom presets from form builder that I created? I uninstalled, reinstalled CFB and they are still showing up.
Thank you,
Diana
Thank you,
Diana
Remove them from the Preset manager.
Go to Insert -> WebAssist -> Preset Manager.
form the product select list, choose CSS form Builder, you can then delete any of the presets you wish.
You can do this by going into Insert->WebAssist->Preset Manager and then selecting form builder from the drop down list. There should be 3 different ones for form builder, so you would want to select the correct one you want to delete from. Then select the preset you want to delete and hit the Remove button.
Glad to be of help. If you have any additional questions or issues, feel free to open a new thread.
I too would like to delete a preset. However when I go to Insert->WebAssist->Preset Manager I cannot select the preset I wish to delete.
I wish to delete Contact/ Quotation but as you can see in the attached image there is no delete button.
Can you please advise?
Many thanks
John
In the first Preset manager screen, Select Contact then click the remove button, in the second screen, select Quotation then click the OK button to remove it.
Thanks Jason
I thought that might be the method, thanks for the quick explanation.
John
