No sending, no redirecting and stuck error messages
Thread began 1/17/2010 1:43 pm by dianadolce243401 | Last modified 1/18/2010 2:06 pm by dianadolce243401 | 3588 views | 13 replies |
dianadolce243401
Having issues with Contact Form Solution Pack..............
Added two new input labels as per forum instructions, removed the red border on the error message and now the form won't send or redirect to my thankyou page and the errors are visible before anything is typed in the boxes.
Soooo perplexed here...............can anyone take a look and help me?
contact4.php
Most grateful,
Diana
neilo
Hi Diana,
I know nothing about PHP, but I have heavily customised a Contact Form SP too; the only thing I notice on you page that's different from mine is that I put the four 'var sprytextfield' lines (and the script tags) below my footer, immediately before the closing </body> tag.
This is more of 'spot the difference' than a sensible suggestion.
neilo
You could also upload a clean copy of the original Spry folder just to confirm whether the error is in the spry files you modified (the css for the red border etc is in the two css files in the Spry Assets folder) or in your contact page.
neilo
I went to your form and filled it out (it looked clean when I got there). I sent a test message, and the error messages appeared. I tried again, but when I refreshed the page, my name (neilo) was still in the 'name' field.
I closed the browser window, cleared my cache /*edit: But not the cookies */ and went back to your contact form page. My name was still in the 'name' field. and the error messages were still displaying.
I have no idea how that could happen, unless it is somehow being cached on your server, or the session error is being written to a cookie (is that possible? Is that even a thing?)
The same thing seems to be happening with two PowerStore Installations (one resolved - maybe) where there is an initial problem with file upload validation, but the error is being 'stored' and persists thereafter (even though the files are being uploaded fine without you knowing it unless you look in the server uploads folder).
I would try uploading your form page and the Spry Assets again (delete them off the server first and go to your contact page and refresh to make sure they've gone).
Edit: I initially just closed the FF Tab that the page was on, and cleared the cache. This time I closed down the actual browser, and the error messages went. But the form still fails on fields after the 'name' field (which isn't a validated field).
Edit 2: Yes - the cookie that stores the session id (PHPSESSID) is preventing me from refreshing the form and is making the errors stick until I close the browser. Sorry for the ramble, Diana.
dianadolce243401
Hi Neilo,
Thanks for trying to figure this problem out............very perplexing.
What is happening to you has been happening to me all day with my name staying in the name field, and the errors coming back each time I view the page. I did everything you suggested and it is still going on. I just don't get it!
I went with the CF solution pack because the CSSform builder is even worst. Can't even modify the original CFSP contact.php in CSSForm builder because it completely messes it up so much that I didn't think anyone would want to help fix it. I really have had great success with WA and hopefully this one glitch will go away very soon.
Any other suggestions????
Diana
neilo
I know how frustrating this is, - I did go through something similar. What I didn't know then that I do know now, is that when testing and you come upon an error, once you've tried stuff and reuploaded files etc, you must close the browser completely and then reopen it before going to your page to see if your modification was any good.
It might help you to have a look at my Spry .css files - the ones that I modified but work OK (and perhaps try substituting them for yours to see if that makes a difference), so I attach them here. You might get something from looking at the contactus.php page code too, so I include that.
But the WA Guys will be in tomorrow, and will probably have a fairly instant logical answer, so make sure to back up your files first if you should decide to try these 'known' working ones as I think they would want to see your originals. (You can see my heavily css-ified example form here. Feel free to send a message - the thank you page is styled similarly.
cfsp_mod_neilo.zip
dianadolce243401
Hi Neilo,
I tested your contact page and it is doing the same thing to me. Even using a different computer this time. I thought maybe the reset button would do the trick, but it still resets to what I typed in even after it was deleted. Something is just not right huh? I started with the contactus.php code and copied it into my existing page. Last night I was hoping the problem was that I put it into a table td and not a div, but since yours in in a div and the same thing is happening again, this doesn't make sense.
I really do appreciate your help and maybe like you said the WA support today may have other suggestions. In the mean time I will pour over your code and see what changes there are compared to mine.
Most grateful,
Diana
neilo
Hi Diana,
I got your form to work OK (not on your site - but redoing your pages here).
I am just cleaning things up a bit, then if you want them I could upload the pages. They should work fine. (you will have to put your email address back in to the WA_Globals). No problem if you are already sorted!
dianadolce243401
Sure Neilo, that would be great! Was there alot of clean up?
I have created another plain paged test form with FB and like others on the forum my captcha won't show. My GD library is up to date. Haven't added functionality with UE yet, could that be the cause? Trying everything I can think of to get a handle on this. Not as easy as WA says that's for sure.
Thanks again for everything you are doing to help me..................
Diana
neilo
Hiya Diana,
No problem, I'm afraid (sadly) that this constitutes 'fun' for me. :(
I have done a mish-mash of yours and my files, to get the functionality, and just need to get the styles finished.
Hopefully you will just need to drop the contactus.php & thankyou pages and a CFSP folder in to your site, put your email address in the WA_Globals.php file and upload. I will need to send this privately, as the files are pretty much all the CFSP and this is a public forum. It is easier that way than sorting out all the separate bits.
Drop me an email: neil [at ] yeractual [.] com , or send one via my demo form page.
