CSS menu writer & DW8/ASP
Hi
I want to upgrade to CSS menu writer 2.
Can anyone confirm it works with DW8 and ASP VBscript.
TIA.
Hi
TIA.
CSS Menu Writer v2 is only supported on CS4 and CS3. Also, PHP is the only supported server language. So unfortunately, you will not be able to develop on DW8 and on ASP. We apologize for any inconvenience this has caused you. We are currently in the process of converting our products to use PHP as the only server language due to the high usage of this server language.
