Alternate Payment Gateways
Hi
I sit possible to setup a different payment gateway to the ones that are listed?
If so how?
Please advise Thanks
Hi
If so how?
It is possible to use other payments gateways than the supported ones that are listed. This process is a custom one though and will require you to obtain documentation from your merchant gateway and implement it with the eCart code.
If you can get some example scripts for the checkout you can replace values in the script with values from eCart.
