ecart versus powerstore
Thread began 12/14/2009 11:36 am by biz295654 | Last modified 12/14/2009 3:49 pm by Justin Nemeth | 631 views | 1 replies |
Is there an overview of ecart and powerstore available? Which one to use? differences? I have both, but not clear on which is the one to dig into and learn.
Justin Nemeth
PowerStore is a pre-built solution meaning after you plugin your settings, you will have a fully functioning store. This solution requires PHP and MySQL, but does not require Dreamweaver.
eCart is a Dreamweaver extension. You can use the extension to build functionality like PowerStore has. Basically, PowerStore is the end result of using eCart to build an online store.
