Multiple Insert - doesn't recognise repeat selection
Thread began 12/13/2009 7:32 am by info97301 | Last modified 12/14/2009 6:25 pm by Jimmy Wu | 1024 views | 2 replies |
info97301
Hi
I've ploughed through the numerous postings relating to the multple insert behaviour, but none of them apply to this.
I have built the form and applied the repeat selection (though the region isn't then displayed on the page as in the tutorial) When I go to 'Data Assist | Insert | Multiple Record Insert' I get an error message saying:
Your page must contain form elements in a repeated region to use this interface'.
I have tried this about 20 times now and always get the same!
I have looked at the tutorial (numerous times) and have followed it exactly.
Using DW8 and Classic ASP (VbScript)
Help much appreciated.
Chris
info97301
Have deleted the extension (realised I was a dot release out from the lateste version) and installed the latest, which has solved the problem.
However, now getting the error as described in posting:
showthread.php?t=5000&highlight=assignment%3A
Will add to that post!
Jimmy Wu
Glad you were able to determine the issue. Please feel free to open a new thread if you run into any additional issues.
