Email not working
The re-direct of the submitted form to a thank you page works fine. However, no email is showing up. Please help. The contactus page can be found here contactus.php
Sorry, it worked after all on the latest attempt. A mystery why all previous didn't.
The page re-directs just fine until I try to add a file upload feature using digital file pro 2. Specifically the directions for including attachments with the email form. When I follow those instructions and complete the form, it re-directs to a blank page. I notice the address in the tab rather than just referring to the page name, now includes the entire address to my local testing server (localhost). Any insights about what may be happening would be greatly appreciated. Been toying with this form longer than I planned. Thanks.
Peter
The blank page indicates that a php error is occurring but error reporting is turned off.
Add the following code at line 1 to turn error reporting on:
error_reporting(E_ALL);
post back the error and a copy of your page so we can have a look at the code.
Here is the error:
Parse error: parse error, expecting `T_STRING' or `T_VARIABLE' or `T_NUM_STRING' in C:\xampp\htdocs\WFA IQ\WA_Universal_Email\WAUE_contact_1.php on line 25
A copy of the contactus page is here:
contactus.php
OK, Can you send a copy of the WA_Universal_Email\WAUE_contact_1.php file so I can examine the code to see what is on line 25.
It's not letting me upload it. Says it's an invalid file.
As my brain slowly grasped the possibilities at the end of the day, I realized a text file would probably meet your needs. See attached.
