SubMenu is behind my Main Menu
Thread began 12/10/2009 12:04 pm by chase.vincent395941 | Last modified 12/18/2009 11:36 am by Jason Byrnes | 4301 views | 18 replies |
chase.vincent395941
I'm creating a navigation bar and the sub menu pops out but it is behind the main menu and I don't know how to fix it. I have attached a picture and my menu.css file Any help would be appreciated.
menu.txt
neilo
try adding a z-index to the sub-menu css:
ul#cssmw0 ul.level-1 > li > a {
height: 10px; width: 121px
z-index: 999;
chase.vincent395941
That didn't do it but thanks neilo
neilo
The z-index of the top level is set to 9999
ul#cssmw0 li {
background-image: none;
float: left;
padding: 0 0 0 0;
position: relative;
white-space: nowrap;
z-index: 9999;
Try setting this to a lower number than the sub-level. (-1)
Neilo is correct that it should be fixed with a z-index rule, if z-index is not fixing it, there may be some other conflicting css. Please send a link so we can take a look at the problem in a browser to get to the bottom of the problem.
chase.vincent395941
You can visit the site at homepage.html
The first tab "Sales Plan" has 3 sub-menus that fall behind the main menu. I tried fixing the z-index number but still not working.
Any other ideas.
neilo
Hiya,
In your 'cssmw1/menu.css':
Remove the 'z-index: 100;' from your 'ul#cssmw1 li' style (about line 23):
ul#cssmw1 li {
padding: 0 0 0 0;
position: relative;
and add it to your 'ul#cssmw1 ul.level-1' style (about line 77):
ul#cssmw1 ul.level-1 {
left: 132px;
margin-right: 25px;
z-index: 100;
chase.vincent395941
Neilo,
That fixed it for Firefox but not IE. I tried changing it in the other style sheets as well but no luck.
\cssmw0\menu.css
\cssmw0\menu_ie.css
\cssmw1\menu.css
\cssmw1menu_ie.css
neilo
Can Jason come back in on this one please?
For me this is testing fine on Firefox, Safari and IE8 (Vista). It is failing in IE7, which is very quirky when it comes to z-indexes.
I have tried many combos including setting the position values for the z-index properties, but am still getting a problem in IE7.
I think we need Jason back in on this.
The only thing I would suggest is to not have the first and second level menus overlapping at all, thus negating the need for a fix.
chase.vincent395941
Neilo,
I know IE7 has a lot of problems but most of our users have not updated yet. Would i have to create a new nav. bar for them to not overlap or is that something you can control in the settings? Sorry for so many questions, I'm new at this.
Chase
