Thanks Victor,
Not sure what you want to do with the horizontal top-menus, at the moment you have four of them (AboutUs, Donate, ReStore, Home) as CSSMenuwriter menus, and the other three (Homes, Volunteer, Photos) as javascript menus. Are you planning to change those too?
You can change the vertical (CSSMW) menus by adjusting the css as described below, but the vertical sub-menus on all the 'Homes' and 'Volunteers' pages (18 of them) and some of those under the other pages which are still javascript menus can only be changed in the javascript files themselves in the 'LeftMenuData' folders in their respective directories. I don't know if you are keeping those javascript menus or changing them to CSSMenuwriter. Have you decided?
Your 'Photos Pages' has a different menu system from the rest - specially for the gallery pages. I take it that shouldn't be touched.
For the moment, to change the vertical sub-menus for the main (CSSMenuWriter) 'AboutUs', 'ReStore' and 'Donate' pages to look like your 'AboutUs' page, you will need to make these changes to your CSS files:
1. In CSSMenuWriter/cssmw1/menu.css
Change font-size from '16' to '11' , and change font-weight from 'bolder' to 'normal' in this rule:
ul#cssmw1 > li > a {
background-color: #51b948;
background-image: none;
background-position: left;
border-style: none;
color: #FFFFFF;
display: block;
font-family: Arial, Helvetica, sans-serif;
font-size: 16px; /* change this to 11px */
font-style: normal;
font-weight: bolder; /* change this to normal */
margin: 0 0 0 0;
padding: 3px 3px 3px 3px;
text-decoration: none;
text-transform: none;
width: 138px;
2. In CSSMenuWriter/cssmw2/menu.css
ul#cssmw2 > li > a {
border-style: none;
color: #FFFFFF;
display: block;
font-style: normal;
margin: 0 0 0 0;
width: 100px;
4. Your main horizontal menu in your 'Home' page (index.htm) - is currently linked to the 'cssmw1' styles and script, so if you change that, it will also change the vertical menu in your Donate page. If you don't want to change it you can leave it as it is. If you do want to change it, you will need to seperate off the css files.
If you are not planning on changing the javascript menus under the 'Homes' and 'Volunteer' pages and want me to look at changing those font styles, let me know.
