PHP/MySQL errors in wagmp_map file
Thread began 12/04/2009 7:57 am by millerb395386 | Last modified 12/07/2009 3:37 pm by Jason Byrnes | 3468 views | 14 replies |
millerb395386
Hello all,
I was able to successfully create a dynamic map on the first go. I went back to add content to the custom display and now I've managed to break things. I completely ripped out the old code and includes inserted by Pro Maps and started over but I am unable to get past this error in the inserted code.
Warning: mysql_fetch_assoc(): supplied argument is not a valid MySQL result resource in /home/rmgoorg/bryantest/merchant/google_javascript/wagmp_map_1.php on line 261
Warning: mysql_data_seek(): supplied argument is not a valid MySQL result resource in /home/rmgoorg/bryantest/merchant/google_javascript/wagmp_map_1.php on line 262
The site is map_view.php
Cheers
It looks like 2 of the the map script tags are added in the wrong place. They should be added to the page just before </head> tag, but it looks they are on the page before the <doctype> tag.
If you are having trouble spotting the problem, please send a copy of the map_view.php page so I can examine the code.
millerb395386
Yes, I noticed that. That was one primary difference between the first (successful) run and subsequent (failed) runs. Whoever developed the site did many naughty things such as closing open tags inside SSI includes, etc. I wonder if that is what is throwing things off.
I will move the script tags and see what happens.
millerb395386
Thanks Jason!
I was able to get it working by moving the script tags as you mentioned. They were way off.
Two other items. I am not able to get the the business_address field to show up in the info window even though I have a custom window as follows (and business_name is in the record set):
<strong>Merchant:</strong>
<?php echo $row_Google_Recordset['business_name']; ?>
<?php echo $row_Google_recordset['business_address']; ?>
<?php echo $row_Google_recordset['city']; ?>,
<?php echo $row_Google_recordset['state']; ?>
<?php echo $row_Google_recordset['zip']; ?>
The business_name never shows up in the window.
Please send a copy of your google_javascript/wagmp_map_1.php fil so I can look at the code.
millerb395386
Do you prefer email or shall I post it here?
millerb395386
Note: I removed function definitions in the prologue as the snippet was too long for the forum.
function wagmp_map_1() {
if(GBrowserIsCompatible()) {
if(!document.getElementById('wagmp_map_1')) return false;
var map = new GMap2(document.getElementById('wagmp_map_1'));
wagmp_map_1_obj = new WAMapRef(map);
map.enableContinuousZoom();
map.enableDoubleClickZoom();
map.addControl(new GSmallMapControl());
var geocoder = new GClientGeocoder();
var fromAddress = {
enabled: false,
street: '',
city: '',
state: '',
zip: '',
country: '',
full: ''
var icon_0 = new GIcon();
icon_0.image = 'plugins/google_javascript/images/traditionalflat_pacifica.png';
icon_0.shadow = 'google_javascript/images/traditionalflat_shadow.png';
icon_0.iconSize = new GSize(34,35);
icon_0.shadowSize = new GSize(34,35);
icon_0.iconAnchor = new GPoint(9,33);
icon_0.infoWindowAnchor = new GPoint(19,0);
icon_0.printImage = 'plugins/google_javascript/images/traditionalflat_pacifica.gif';
icon_0.mozPrintImage = 'plugins/google_javascript/images/traditionalflat_pacifica_mozprint.png';
icon_0.printShadow = 'google_javascript/images/traditionalflat_shadow.gif';
icon_0.transparent = 'google_javascript/images/traditionalflat_pacifica_transparent.png';
<?php $Google_recordset_id = 0; ?>
<?php do { ?>
var address_0_<?php echo $Google_recordset_id; ?> = {
street: '<?php echo str_replace("'", "\'", "".$row_Google_recordset['business_address'] .""); ?>',
city: '<?php echo str_replace("'", "\'", "".$row_Google_recordset['city'] .""); ?>',
state: '<?php echo str_replace("'", "\'", "".$row_Google_recordset['state'] .""); ?>',
zip: '<?php echo str_replace("'", "\'", "".$row_Google_recordset['zip'] .""); ?>',
country: '',
infowindow: 'custom',
infowindowtext: '<span style="font: 12px Verdana, Arial, Helvetica, sans-serif; color: black;"><?php echo str_replace("'", "\'", "<strong>Reported Merchant:</strong><br />".$row_Google_Recordset['business_name'] ."<br />".$row_Google_recordset['business_address'] ."<br />".$row_Google_recordset['city'] .", ".$row_Google_recordset['state'] ." ".$row_Google_recordset['zip'] .""); ?></span>',
full: '<?php echo str_replace("'", "\'", "".$row_Google_recordset['business_address'] .""); ?>, <?php echo str_replace("'", "\'", "".$row_Google_recordset['city'] .""); ?>, <?php echo str_replace("'", "\'", "".$row_Google_recordset['state'] .""); ?>, <?php echo str_replace("'", "\'", "".$row_Google_recordset['zip'] .""); ?>',
isdefault: true,
addressType: 'address',
loop: 'Google_recordset',
latitude: '',
longitude: '',
markerStyle: 'Google Traditional (flat)',
markerColor: 'Pacifica'
if (address_0_<?php echo $Google_recordset_id; ?>.addressType == "coordinates") {
var cacheReturn = '';
} else {
var cacheReturn = searchCache(address_0_<?php echo $Google_recordset_id; ?>.full, address_0_<?php echo $Google_recordset_id; ?>.zip);
if (cacheReturn != "" || (address_0_<?php echo $Google_recordset_id; ?>.addressType == "coordinates")) {
if(address_0_<?php echo $Google_recordset_id; ?>.addressType == "coordinates") {
var latitude = address_0_<?php echo $Google_recordset_id; ?>.latitude;
var longitude = address_0_<?php echo $Google_recordset_id; ?>.longitude;
} else {
var latitude = cacheReturn.substring(1,cacheReturn.indexOf(",")-1);
var longitude = cacheReturn.substring(cacheReturn.indexOf(",")+1,(cacheReturn.length)-1);
var point = new GLatLng(latitude, longitude);
if (point && !isNaN(latitude)) {
wagmp_map_1_obj.addressFailed = false;
var marker_0_<?php echo $Google_recordset_id; ?> = new GMarker(point, icon_0);
GEvent.addListener(marker_0_<?php echo $Google_recordset_id; ?>, 'click', function() {
marker_0_<?php echo $Google_recordset_id; ?>.openInfoWindowHtml(address_0_<?php echo $Google_recordset_id; ?>.infowindowtext);
if(!fromAddress.enabled || 'address_0_<?php echo $Google_recordset_id; ?>' != 'address_0_0') {
if('address_0_<?php echo $Google_recordset_id; ?>' == 'address_0_0')
map.setCenter(point, 13);
map.addOverlay(marker_0_<?php echo $Google_recordset_id; ?>);
map.setZoom(12);
wagmp_map_1_obj.markers.push(marker_0_<?php echo $Google_recordset_id; ?>);
wagmp_map_1_obj.addresses.push(address_0_<?php echo $Google_recordset_id; ?>);
wagmp_map_1_obj.icons.push(icon_0);
wagmp_map_1_obj.points.push(point);
} else {
if (wagmp_map_1_obj.addressFailed) {
map.setCenter(new GLatLng(30, -98), 3);
wagmp_map_1_obj.addressFailed = true;
} else if (address_0_<?php echo $Google_recordset_id; ?>.addressType == "address") {
geocoder.getLatLng (
function(point) {
if(point) {
this.addressFailed = false;
addToCache(address_0_<?php echo $Google_recordset_id; ?>.full, '', point);
} else {
var noZipAddress = address_0_<?php echo $Google_recordset_id; ?>.full.replace((address_0_<?php echo $Google_recordset_id; ?>.zip+','), '');
geocoder.getLatLng (noZipAddress,
function(point) {
if(point) {
addToCache(address_0_<?php echo $Google_recordset_id; ?>.full, address_0_<?php echo $Google_recordset_id; ?>.zip, point);
if (!fromAddress.enabled || 'address_0_<?php echo $Google_recordset_id; ?>' != 'address_0_0') {
} else {
<?php $Google_recordset_id++; ?>
<?php } while ($row_Google_recordset = mysql_fetch_assoc($Google_recordset)); ?>
<?php mysql_data_seek($Google_recordset, 0); ?>
I do not see any problem in the code, can you double check in the database that the business_name column has a value. It would seem this column is empty in the Database.
millerb395386
When I test the recordset using the "Test Connection" button in Dreamweaver it clearly shows values for the business_name field. Also, browsing the MySQL database shows them to be there as well.
millerb395386
I think I see the problem. Google_recordset for business_name has a capital "R" on recordset. I'll re-run and see what happens.
