Bad File Management
Thread began 11/24/2009 10:46 pm by anonymous | Last modified 11/25/2009 9:27 am by Jason Byrnes | 1103 views | 4 replies |
anonymous
Bad File Management
Hey Guys... can you please think about file management BEFORE you release products? PLEASE? I own both Power Store and Power Gallery - which you guys assume we users will use together - BUT THERE IS A HUGE problem - instead of PREFIXXING folder and files differently you use the SAME folder directories for BOTH scripts/apps - come on GUYS... I know you are smarter then this.. after ALL you are WEBASSIST the industry leader RIGHT?
So why do I or your other users need to point this out to you? -
i want to use BOTH scripts - but without jumping thru major HOOPS i cant... any suggestions? thanks RV
Office Guy-172461
I just install PowerGallery in it's own folder.
anonymous
NOT a simple solution
Yes you can put ANY PHP script in it's OWN FOLDER
but then you have to RE-path all the support files ie: connections folder etc
this is a HUGE - HOOP JUMPING option - if it was developed RUGHT to begin with users would NOT have to jump thru hoops :(
Office Guy-172461
I uploaded PowerGallery to it's own folder, ran the installation wizard, and started using it. Not that big a deal.
There is no hoop jumping needed,
Put the PowerStore files on your server at:
powerStore
and the PowerGallery files at:
PowerGallery
There is no re-pathing that will need to be done.
They are 2 separate solutions so are intended to be in separate folders on your site.
Just like you would install Dreamweaver CS3 into a separate folder from Dreamweaver CS4, you should install PowerGallery into a separate folder from PowerStore.
