Setting up a new database connection in Dreamweaver
Thread began 11/23/2009 4:36 pm by anikbrownmarketing393688 | Last modified 9/17/2013 1:53 pm by Jason Byrnes | 15021 views | 48 replies |
Please help,
I am creating a directory website and desided to use a few webassist products to automate the process. Yesterday I worked for three hours trying to fix a connection error and I finally did. I was able to connect to my database on my remote server and view all of my tables.
Now today when I started to work on the site after downloading a few more webassist extentions I could nolonger get my database connection to work.
It tells me that "an unidentified error has occured" and nothing else. My Remote server is testing correctly and so is my test server which was the problem yesterday. Since that is not the issue this time I can not figure out what the problem could be.
Please help!!!!!!!!
Office Guy-172461
See if these help:
How to create a connection to a MySQL database
157/
Creating a dynamic site definition in Dreamweaver
151/
Also rebooting your computer sometimes solves weird problems.
im-altos
Thank you very much for your reply. I have followed these steps over and over again and I am still not able to get a working database connection. It's crazy becuase it was working just lastnight and I was able to access my tables from Dreamweaver. Now I am getting "unidentified error" could this have anything to do with me downloading Boss, security assist, and file manager from the extention librabry. That is the only thing I have done since last night.
Thanks,
Office Guy-172461
It shouldn't, but maybe the cache got corrupted.
Try step 1:
Solving problems with Dreamweaver
146/
giray_turan394587
hello,
i have the similar problem and i am trying to solve it since 5 days. I followed all the steps that has been shown here but i still have this problem.
the problem is when i click + button to add MySQL Connection in Dreamweaver CS4, I get the form to fill and i fill it exactly as it was described in the guide that u linked but still i get "An unidentified error has occured" message.
i googled the error msg and trying to fix it since 5 days. pls help and save my nerves.
more exact info here:
I am trying to connect to mysql database throught dreamweaver cs4 in an PHP environment. I use IIS7 (i know, it is not recomended.)
I reconfigured IIS and my server root folder is "C:\grytrn\"
I installed PHP on IIS while UAC was off
I installed mysql and phpadmin as it was described in adobe website.
I dunnow what is wrong here.. do you have any ideas?
Office Guy-172461
Have you tried this guide?
146/
grytrn
yes i did, it did not help :(
Office Guy-172461
This is one of the reason's I don't use IIS - too many weird problems. I switched to XAMPP years ago, and haven't looked back
Have a look at this:
How to set up a local testing server for Dreamweaver
144/
grytrn
ok thanks, i will try that out,
if it wont work, then i will uninstall IIS as well. thanks for your time.
Office Guy-172461
You're welcome. Don't forget that you can't have 2 web servers on the same port at the same time, so either change the port of one or un-install the one you don't use.
Let us know how you make out. I can add clarification to the instructions if you find a sticking point.
