Multipel Record Update - ASP - Error JavaScript when applying
Thread began 11/06/2009 4:05 am by info216840 | Last modified 12/15/2009 11:09 am by Jimmy Wu | 3593 views | 11 replies |
info216840
I have to modify an old site to update all records with one click.
I had used ASP-Access to realize it. I'm using CS3 on a MacOSX 10.5.8
When I apply the "Multiple Record Updates" behavior, I get a JavaScript error like this:
"During the execution of applyServerBehavior in
WADA_MultiUpdate.htm, a JavaScript error has verified."
I don't know if it is a script problem, but I attach the code.
Alex
PS: Does WA_AppBuilder_VB.asp require?
c_stampe-upd_3.zip
Jimmy Wu
Try following the steps outlined in the "Common Installation Issues" document:
Alexneg66
Originally Said By: Jimmy Wu
Thank you Jimmy Wu,
I have followed "common_installation_issues" step by step.
I erased "MacFileCache-xxxxxxxx.dat" file opened, I got error.
I closed DW, I erased "MacFileCache-xxxxxxxx.dat" file again, opened DW, I got error.
I uninstalled "DataAssist 206" and I installed again, I got error.
I erased "MacFileCache-xxxxxxxx.dat" file opened DW, I got error.
I surrender
I am in a hurry to conclude a work. I didn't think to have so much problem.
Please tell me some other advices.
Thanks again
Alex
Alexneg66
I have also tried in another HD, on a brand-new installation but now with DW CS4 (MacOSX 10.5.8, DW 10, DA 206 only one ext.). I get the same error.
Alexneg66
Cans no one help me to get out of trouble?
Jimmy Wu
I am able to add the multiple record insert server behavior without any errors. Was this behavior happening for you with the previous versions of DataAssist or is it a new issue?
Alexneg66
I am using: MacOSX 10.5.8, CS3 (and CS4) and DataAssit 2.0.6 with ASP VBScript.
I get the same JS error with the both CS versions (CS3 and CS4).
To verify it with the CS4, I have used a new internal hard disk with a new MacOSX and CS4 installation and DA 206 is the only ext installed.
Thnks
Alex
Jimmy Wu
Are you on a Power PC or Intel Mac?
Alexneg66
Intel Mac (MacPro3,1 Quad-Core Intel Xeon)
Jimmy Wu
I haven't been able to reproduce this issue on our setup. Can you post a screen shot of the error message and exact steps you took to get this error?
