syntax error and error basic set up
Thread began 11/04/2009 5:34 am by info271221 | Last modified 11/04/2009 12:09 pm by Jason Byrnes | 911 views | 1 replies |
info271221
On the confirm page I am getting this error - PHP Parse error: syntax error, unexpected ';' in D:\Websites\www.MYSITE\ShopTheHorseMall\confirm.php on line 3
Also, MYSITE is very large and I would prefer to have a separate set of eCart Files for each subsite. I set up a new dreamweaver site in wamp/www/ShopTheHorseMall and used that as the local path - then ShopTheHorseMall as the live connection. The database connected fine... however the eCart files were generated in wamp/www (the root of www NOT ShopTheHorseMall AND some one of the re-directs sent to MYSITE/Accounts/cart_display - Not sure why that happened. What would be the best way to set eCart up for my subsites?
Files attached
line 3:
require_once(("WA_eCart/eCart1_PHP.php");
should be:
require_once("WA_eCart/eCart1_PHP.php");
The eCart files will all be stored at the rot of the Dreamweaver site.
using your currant setup, you need to create a uniquely named eCart object for each subsite.
another way to go about it is to create new Dreamweaver site for each sub site, and "put them together" when uploading to the server.
for example:
Site 1:
Site folder: c:\websites\site1
site 2:
Site folder: c:\websites\site2
site 3:
Site folder: c:\websites\site3
them on the remote tab, set then upload to:
Site 1:
host directory: httpdocs/site1
site 2:
host directory: httpdocs/site2
site 3:
host directory: httpdocs/site3
