View uploaded files in site admin
Thread began 10/27/2009 10:07 am by jenkolaka19379118 | Last modified 10/28/2009 10:24 am by Jason Byrnes | 1263 views | 3 replies |
jenkolaka19379118
I am really confused on how to create the following.
I have a front end where a user can upload there CV. When this is uploaded i simply want to be able to download/open the file via my backend "detail.php" page via a link/button using dataassit. I have created the upload form and the datassist backend pages using the wizard but I am now stuck on the following.
how do i turn the filename from the database into a download link on my details page. I know the detail page just echos a record so im not sure how to modify it so when i click on the filename it automatically opens in e.g. word or adobe reader?
on the results page, add a form to the results display. It will only need to have a hidden form element and a submit button.
set the name of the form to use the ID column from your recordset and leave the action blank:
<form name="download_<?php echo $row_rsName["ID"]; ?>" id="download_<?php echo $row_rsName["ID"]; ?>" method="POST"  action="download_<?php echo $row_rsName["ID"]; ?>">
in the hidden form element, set the init value to the file name column from the recordset.
Add the Digital File Pro Download file server behavior. Set the folder to the same folder used as the upload location, click the lightning bolt next to file name and select the hidden form element.
jenkolaka19379118
Success
Thanks a Million Jason,
That works perfectly. I used it on my details page, but I am hopeful it will work on the results page like you suggested so I can instantly view and download from many records on the results page as that would be very helpful.
You're welcome.
