Invalid file type error when uploading doc and pdf
Thread began 10/26/2009 10:20 am by info97301 | Last modified 11/11/2009 12:02 am by henk303241 | 58707 views | 10 replies |
info97301
Hi
Have installed HTML Editor. Image and swf upload both work perfectly, but when I try to upload pdf or doc files, I get an 'invalid file type' error. Looking though the config files, these seem to be allowed, so is there some other setting required?
john.carter13796
same here
For the record I have the same problem.
anonymous
Are you guys referring to the Advanced File Manager or the the basic one?
Brian
Jimmy Wu
When setting up the upload manager, make sure you set up the Advanced File Manager by creating a connection to a database. To setup the Advanced File Manager, open up the HTML Editor wizard (by clicking on an existing one and hitting edit or inserting a new instance) and click on the customize next to Global File Upload Settings. In the HTML: Site Settings dialog, make sure to set a connection in the Advanced File Manager section.
Using the simple upload manager, uploading pdfs and docs will throw that error.
info97301
Why the difference?
Hi Jimmy
If I click on 'browse server' I can upload a doc (and presumably other formats too) from there, but if I click the upload tab then 'send to server' after selecting a file, I get the error message. However, if I choose the latter route for uploading an Image or Flash movie, I don't get any error. Seems inconsistent and likely to confuse the end user.
Having managed to upload a file, I now get the error when I try to update the page.
Warning: Cannot modify header information - headers already sent by (output started at /home/...../public_html/adminsection/admin/pagesform3.php:4) in /home/...../public_html/adminsection/admin/pagesform3.php on line 58
which I didn't receive yesterday!
Cheers
Chris
Jimmy Wu
This error is usually caused by having whitespace between php tags on that page. Make sure there is no whitespace between your php tags. Here is an example:
You'd want it to look like this:
Thanks for bringing that to our attention. We have logged a bug for this and this should be fixed in a future release.
anthony355121
Im having the same issue - can upload images via image link - cannot upload documents via link manager. Ive checked code and no space b/c php tags ...
Jimmy Wu
Do you have a link to a page that I can see this behavior?
henk303241
I have the same error here, no pdf....
I found a workaround:
In the file HTMLeditor/editor/filemanager/connectors/php/config.php
Change line 141 into: $Config['AllowedExtensions']['Image'] = array('bmp','gif','jpeg','jpg','png','pdf','doc') ;
That'll do the trick... seems a bug :).
Jimmy Wu
Thanks for bringing this to our attention. I'm glad you are able to find a workaround for this.
