eCart update
Thread began 10/22/2009 4:14 pm by kevin.preston332611 | Last modified 10/26/2009 12:47 pm by Jason Byrnes | 3410 views | 4 replies |
kevin.preston332611
eCart update
I have bought and installed Power Store on my temp site (ingnore all otehr pages pages): Products_Results.php?Search=true&CategoryID=1.
I need to get PS to work with Pay al Standard (I dont need inventory management).
After looking through the forums I used eCart 4 to change the gateway as suggested here: ps_change_pmtgateway_ecart.pdf
I have set up a sandbox account in paypal and entered all the information but I get an error when I fill in the form:
Warning: require_once(/WA_eCart/Adv_CO_Scripts/PP_DirectPayment_PHP.php) [function.require-once]: failed to open stream: No such file or directory in /home/jesssys/public_html/sfk/confirm.php on line 13
Fatal error: require_once() [function.require]: Failed opening required '/WA_eCart/Adv_CO_Scripts/PP_DirectPayment_PHP.php' (include_path='.:/usr/lib/php:/usr/local/lib/php') in /home/jesssys/public_html/sfk/confirm.php on line 13
Any ideas? I need to get this working asap. Please help!
Cheers,
Kevin
Sounds like the require_once command at line 13 was coded as:
require_once("/WA_eCart/Adv_CO_Scripts/PP_DirectPayment_PHP.php")
try removing the leading forward slash:
require_once("WA_eCart/Adv_CO_Scripts/PP_DirectPayment_PHP.php")
Most likely it is being added as a result of the "Create Links relative To" setting on the Local Info tab of your site definition. Set that option to Document instead of Site.
kevin.preston332611
eCart
I tried what you suggested, but in the meantime I also tried a few other things recommended in the documentation. currently the error message when I go to the confirm screen is:
Parse error: syntax error, unexpected $end in /home/jesssys/public_html/sfk/confirm.php on line 1397
I cant seem to find where the problem is.
Any thoughts?
K
kevin.preston332611
eCart
Right,
I have started again with the confirm page using the default template to see if I can get it working with that first.
Now when I enter the information and click confirm from the checkout page it goes straight to the checkout_failure.php screen with no real indication why.
Is there a way of tracking why it went to that screen?
Cheers,
Kevin.
see the "Debugging eCart Transaction Failed issues" tutorial in the how to section of the eCart support page:
ecart/
