Insert page not passing variable, no record found
Thread began 10/20/2009 10:28 am by info271221 | Last modified 3/15/2010 12:59 pm by dlovas275157 | 2162 views | 4 replies |
info271221
Here is one of the insert pages:
Load_Insert.php
Here is the details page:
Load_Detail.php
It's not passing the
Load_Detail.php?id=30
Thank You!
I did not see any files or links on this post. From what you are describing it sounds like either the lookup on the detail page is not filtering on the correct value, or the id is not being set to this value.
On your insert have you specified the id column that should be held in a session variable? What do you specify as the name for this value?
On the detail page your recordset should be filtered on this value. Are you filtering the recordset, and if so what are you filtering it on?
info271221
session id passed now!
I fixed the problem. I reviewed other session id that we successfully passed and got it working.
Fantastic, so you just made sure the insert page was storing the id in a session variable then on the detail page you set it up so that the recordset was referencing this value rite?
dlovas275157
I had the same problem while I was developing on a PHP4 server. As soon as I switched to a PHP5 server, my server stored the session variables properly and the redirect to the detai. page worked.
Maybe this will help someone else.
D.
