error with login form on homepage redirecting to https
The login form on the homepage gets access denied everytime I attempt to change the code ""successRedirect" => "mainhome.php"," below for https access.
if($_SERVER["REQUEST_METHOD"] == "POST"){
$WA_Auth_Parameter = array(
"connection" => $NoWayJose,
"database" => $database_NoWayJose,
"tableName" => "NoWayJosetable",
"columns" => explode($WA_Auth_Separator,"User_Name".$WA_Auth_Separator."Password"),
"columnValues" => explode($WA_Auth_Separator,"".((isset($_POST["username"]))?$_POST["username"]:"") ."".$WA_Auth_Separator."".((isset($_POST["userpassword"]))?$_POST["userpassword"]:"") .""),
"columnTypes" => explode($WA_Auth_Separator,"text".$WA_Auth_Separator."text"),
"sessionColumns" => explode($WA_Auth_Separator,"securekey".$WA_Auth_Separator."userLevel".$WA_Auth_Separator."User_Name"),
"sessionNames" => explode($WA_Auth_Separator,"securekey".$WA_Auth_Separator."userLevel".$WA_Auth_Separator."User_Name"),
"successRedirect" => "https://ssldomainhome.com/mainhome.php",
"failRedirect" => "accessdeny.php",
"gotoPreviousURL" => TRUE,
"keepQueryString" => TRUE
WA_AuthenticateUser($WA_Auth_Parameter);
This will only work is I first goto ssldomainhome.com then login from homepage.
