Undefined Variable total pages / clear search
Thread began 10/09/2009 11:06 am by info271221 | Last modified 12/03/2009 5:44 pm by Jason Byrnes | 5846 views | 12 replies |
info271221
I am getting the following error on the bottom of my page.
PHP Notice: Undefined variable: totalPages_WADAbear in D:\Websites\www.myDomain\RecordBear\Bear_Results.php on line 479 PHP Notice: Undefined variable: totalPages_WADAbear in D:\Websites\www.myDomain\RecordBear\Bear_Results.php on line 482 PHP Notice: Undefined variable: totalPages_WADAbear in D:\Websites\www.myDomain\RecordBear\Bear_Results.php on line 537 PHP Notice: Undefined variable: totalPages_WADAbear in D:\Websites\www.myDomain\RecordBear\Bear_Results.php on line 540
Bear_Results.php
Also - if you search something, then browse to another page and click on the link for the measurer again it holds the results for the last search. Is that normal or is their a way to clear the search when you leave the page?
Thanks!
There is a chunk of code that has been removed from the results page.
if you look at the Bear_ResultsBACKUP.php page at line 144 - 158 the code for the WADAbear recordset looks like:
mysql_select_db($database_wibuckbear, $wibuckbear);
$query_WADAbear = "SELECT * FROM bear ORDER BY BScore DESC";
setQueryBuilderSource($query_WADAbear,$WADbSearch1,false);
$query_limit_WADAbear = sprintf("%s LIMIT %d, %d", $query_WADAbear, $startRow_WADAbear, $maxRows_WADAbear);
$WADAbear = mysql_query($query_limit_WADAbear, $wibuckbear) or die(mysql_error());
$row_WADAbear = mysql_fetch_assoc($WADAbear);
if (isset($_GET['totalRows_WADAbear'])) {
  $totalRows_WADAbear = $_GET['totalRows_WADAbear'];
} else {
  $all_WADAbear = mysql_query($query_WADAbear);
  $totalRows_WADAbear = mysql_num_rows($all_WADAbear);
$totalPages_WADAbear = ceil($totalRows_WADAbear/$maxRows_WADAbear)-1;
on the Bear_Results.php page, the code for the recordset is at line 144 - 149:
$WADAbear = mysql_query($query_WADAbear, $wibuckbear) or die(mysql_error());
$totalRows_WADAbear = mysql_num_rows($WADAbear);
This section of code has been removed:
} else {
info271221
Undefined Index ID on results page
THANKS! Now I am down to1 error. I checked the deer page where this function is working and cannot figure out what is wrong.
PHP Notice: Undefined index:
the if statement on line 130:
if ($_SESSION['id']) {
should be:
if (isset($_SESSION['id'])) {
info271221
Search does not clear previous results
If a submit a search on the attached pages, and then submit another search with -0- fields selected the results are retained from my previous search. How do I get it to clear / reset so that it will not retain the previously searched items.
It appears to be working on the attached mydomain.org/member_measurer/member_directory_Results.php as it returns results from the beginning of the alphabet
On this page we are returning results ONLY IF a selection is made which works GREAT on the original search but if you search again and do not make any selections it will still return results
mydomain.org/member_measurer/member_directory_Search_measurer.php?reset=true
Thank You!!
info271221
Manage Page Next, Last is not working correctly
On this page: Load_Manage.php?pageNum_WADAtbl_vehicle_info=1&totalRows_WADAtbl_vehicle_info=21 (Julie / Password) the Next / Last links are not working correctly.
They say 1-20 and pull up 20 (correctly) however then you click on the next or last link and are supposed to see 21-21; however you see all the same listing.
on the search page for the member_directory_Results.php, set the form action to member_directory_Results.php?reset=true
Then add the following code just before the database search code at line 12
if(!session_id()) session_start();
if(isset(
$_SESSION["WADbSearch1_member_directory_Results"]) && isset($_GET['reset']) && $_GET['reset'] == "true") {
  unset(
$_SESSION["WADbSearch1_member_directory_Results"]);
I'll need you to send a copy of the Load_Manage.php page so I can examine the code.
info271221
Measurer Results still does not reset
Files attached mysite.org/http://www.mysite.org/member_measurer/member_directory_Search_measurer.php?reset=true
Is the reset neccessary in the url?
having reset=true in the URL is what are using to clear the previous results.
It should only be included in the URL when you want the previous search results to be cleared.
info271221
Still not clearing
It is not clearing. Please review previously attached files.
You may test here:
