Javascript error at Startup
Thread began 4/08/2009 12:15 am by deanmaury365211 | Last modified 9/10/2009 7:55 pm by jebrandon343719 | 6096 views | 18 replies |
deanmaury365211
When trying to initialize Sculptor, I get this in CS4 Dreamweaver (XP Home)-
While executing onLoad in wacs_wizard.htm, the following Javascript error(s) occurred:
In file "wacs_wizard":
initializeUI is not defined
I tried removing sculptor and reinstalling it a few times and restarting comp, to no avail. Does anyone have any clue on this one?
Thanks in advance,
Dean
Try clearing your winfilecache.dat file in your configuration folder while DW is closed. That can sometimes fix problems like this.
If that doesn't work, please submit a support incident and somebody can look into this with you.
MBrem
Had the same issue. Since I'm on a Mac, trashing the macfilecache.dat corrected the issue.
raf225211
Originally Said By: register313951
I just filled a trouble ticket for this. Seems they should document this in the installation notes since it's a common problem.
We will be updating our installation instructions to include this information. It seems to be introduced in CS4 and we just recently got our heads around the cause.
craiger522323782
[QUOTE=deanmaury365211;2005]When trying to initialize Sculptor, I get this in CS4 Dreamweaver (XP Home)-
I'm having the same problem on a Mac OSX 10.5.6. I don't see a file called "winfilecache.dat" in my config folder. Which file should I look for?
macfilecache.dat
deanmaury365211
Hey Ray,
Thankyou for the quick reply. Where do I find that file? I looked in the DW Configuration folder and the Windows Configuration folder and don't see the file.
Dean
It is in your users local configuration. Users/Library/Applicaiton Support/Adobe/Dreamweaver cs4/en_us/Configuration... or something like that I haven't used a mac in a while.
deanmaury365211
Hey Ray, I see that you've posted on Adobe's site about this and I figured it out from there. Had to use the folders options to show hidden folders to get to it. It did solve the problem. Thanks again much.
Dean
