just need to know what this nasty little message means
Thread began 9/28/2009 9:54 pm by mehd389652 | Last modified 9/30/2009 9:54 pm by neil186288 | 5047 views | 18 replies |
mehd389652
Still Struggling with this:
Here is what I'm seeing
Warning: mysql_pconnect() [function.mysql-pconnect]: Unknown MySQL server host 'http' (1) in /home/pythoni/public_html/CMS100/Connections/localhost.php on line 9
Fatal error: Unknown MySQL server host 'http' (1) in /home/pythoni/public_html/CMS100/Connections/localhost.php on line 9
obviously means something is not right but what ?
It means that the MySQL Host address you entered in the localhost.php file is not correct.
double check the value you have given to the following variable:
$hostname_localhost
Check with your host for the correct address to use for the MySQL Server.
mehd389652
ok this is my domain right $hostname_localhost =""
I should put my domain name between these quotes is that right ?
and is the syntax
www.mydomain.com
or is it
mydomain.com
or is it none of the above
No, it is not the domain name. It is the address for the MySQL server.
mehd389652
Why don't you have something in your documentation
That would at least give some clue as to how this looks
I have contacted my host done everything they said
and it still doesn't work. I have now spent 3 days on
this for no results ?
neil186288
Have you tried:
$hostname_localhost = "localhost";
That should work fine assuming you have uploaded the localhost.php file to your server.
[With mine, while I'm testing on my local machine, I use:
$hostname_localhost = "www.mydomain.com"; (mydomain is my domain name)
I'm able to use that on my local machine because I have set my username in mySql preferences in my control panel to allow % - which is a wildcard symbol means that it will accept connection from any source.]
But just localhost should be fine for a page that's been uploaded.
neil186288
Incidentally, what did your hosting provider tell you to do?
That might help the people here to help you check if you're doing it right.
mehd389652
Hi Neil
They told me to use localhost as you suggest.
But "that suggestion" should be in the notes to give newbies
like myself some clue as to what they are on about and
at least vaguely what it looks like?
They should say something like typically this is "localhost" but
check with your host . . . blah blah.
Thank you for your help though Neil and your information was
quite correct although I don't totally understand your access on
your local machine and you sound like your on a PC I'm on a Mac
anyone who says Macs are easy to use is having themselves on ?
But aren't all computers COWS ?
Ciao,
Mike
mehd389652
Mike here Jayson
$hostname_localhost
Mike said:
$hostname_localhost="localhost"
was the reply from the host and the value
neil186288
I agree with you entirely Mike,
I sometimes feel that the techie types - especially at WebAssist - are genetically incapable of understanding the difficulties that starters have with all of this stuff. Hence the length of some of these threads - when people have to keep posting back to try to get the 'pros' to explain what their last explanation actually meant. It can be like trying to get blood from a stone around here.
Someone from WebAssist could have simply said, 'have you tried: '$hostname_localhost = "localhost";' ?'
But no, that would be damn obvious for these guys.
Good luck
And yes, computers can be cows.
