Can't create a new CSS preset
Thread began 9/26/2009 10:19 am by dianadolce243401 | Last modified 9/29/2009 4:24 pm by Eric Mittman | 2106 views | 5 replies |
dianadolce243401
I just upgraded to CSS sculpter 3, have downloaded it twice now following the installation steps and again deleting the windate file first. I still can not create a new preset. The create new window is blank. I had no problems with CSS 2 version 2.0.5
I am using:
Dreamweaver CS4
Vista 64 bit
Any other suggestions?
Diana
office172461
Long shot
Have you tried a total computer shutdown, wait 30 seconds, and a restart?
dianadolce243401
Hopeful, but no it didn't work to shutdown. When I try and close the css sculptor blank window it takes 3 clicks and says CSS Scultpor is not responding. This is frustrating!
Any other suggestions anyone?
When you deleted the win cache file did you do so before installing or after installing? It should be done after you install the new one as the installation process itself can cause problems with the dat file if you had previous versions installed. Please give this a try to delete the cache file now after the fact or if you have already done that please let us know.
dianadolce243401
I ended up doing a re-install after renaming my config folder to force dreamweaver to recreate the folder. Everything is working perfectly now..............thank you!
Great to hear that, here is a link for you or any one else that one of our Community Experts has put together that lists the steps needed to clear this cache file as well as clearing out the config folder:
146/
Hopefully others will see this one and benefit from your experience.
