DW CS4 Problem
I downloaded the Trial of Dreamweaver CS4 and was really liking it and considering purchasing it until I ran into this problem.
I develop in ASP and PHP. When I tried to run an ASP Program from Localhost I received the following error: "jscript" not installed on the server. or something very close to that.
I was not able to run any scripts on the local server. I uninstalled Dreamweaver CS4 and did a system restore and everything went back to working fine.
What is the problem here?
I certainly can't use DW4 if this is going to happen when I install it.
Thank You,
Bob
