MySQLi file input update query problem with consecutive updates
Thread began 8/02/2023 4:21 am by Willem | Last modified 8/07/2023 8:40 am by Willem | 361 views | 7 replies |
Willem
I am upgrading a website from MySQL to MySQLi. I am updating a form with a file input ('guide_file'). The name of the file is written to 'Studyguide' field in database. Everythings works OK, on the first update submission, but if I update again, NULL is written to the 'Studyguide' field, as is expected. In the old code that did not happen due to the checking 'Studyguide=IFNULL(%s,Studyguide)' that was done.
How do I implement that in the MySQLi update procedure?
The Old code and New code is given below.
Tha
Old code
if ((isset($_POST["MM_update"])) && ($_POST["MM_update"] == "form1")) {
$updateSQL = sprintf("UPDATE moderering_ekstern SET Date_modify=%s, `Year`=%s, Course_name=%s, Studyguide=IFNULL(%s,Studyguide) WHERE id_ecsa=%s",
GetSQLValueString($_POST['Time_modify'], "text"),
GetSQLValueString($_POST['jaar'], "int"),
GetSQLValueString($_POST['vak'], "text"),
GetSQLValueString($_POST['guide_file'], "text")
GetSQLValueString($_POST['hiddenfield'], "int"));
mysql_select_db($database_ecsa, $ecsa);
$Result1 = mysql_query($updateSQL, $ecsa) or die(mysql_error());
$updateGoTo = "edit_list_ext.php";
if (isset($_SERVER['QUERY_STRING'])) {
$updateGoTo .= (strpos($updateGoTo, '?')) ? "&" : "?";
$updateGoTo .= $_SERVER['QUERY_STRING'];
header(sprintf("Location: %s", $updateGoTo));
MySQLi code
$UpdateQuery = new WA_MySQLi_Query($ecsa);
$UpdateQuery->Action = "update";
$UpdateQuery->Table = "moderering_ekstern";
$UpdateQuery->bindColumn("Date_modify", "s", "".($_POST['Time_modify']) ."", "WA_BLANK");
$UpdateQuery->bindColumn("Year", "s", "".($_POST['jaar']) ."", "WA_BLANK");
$UpdateQuery->bindColumn("Course_name", "s", "".($_POST['vak']) ."", "WA_BLANK");
$UpdateQuery->bindColumn("Studyguide", "s", "".($_POST['guide_file']) ."", "WA_BLANK");
$UpdateQuery->addFilter("id_ecsa", "=", "d", "".($_POST['hiddenfield']) ."");
$UpdateQuery->execute();
$UpdateGoTo = "edit_list_ext.php";
if (function_exists("rel2abs")) $UpdateGoTo = $UpdateGoTo?rel2abs($UpdateGoTo,dirname(__FILE__)):"";
$UpdateQuery->redirect($UpdateGoTo);
Instead of:
try:
$UpdateQuery->bindColumn("Studyguide", "s", "".($_POST['guide_file']) ."", "WA_IGNORE");
Willem
Thanks for the propmpt reply, Ray.
That did the trick.
Is there a document available with an explanation of all the options?
Regards
Willem
Willem
Databridge2 File upload problems
The previous problem with the file input update has been solved, but now I experience problems uploading the files.
I have used the Webassist/File manipulation/Upload Files server behavior, which created the following code:
// WA_UploadResult1 Params Start
$WA_UploadResult1_Params = array();
// WA_UploadResult1_1 Start
$WA_UploadResult1_Params["WA_UploadResult1_1"] = array(
'UploadFolder' => "Uploads/",
'FileName' => "[FileName]",
'DefaultFileName' => "",
'ResizeType' => "0",
'ResizeWidth' => "0",
'ResizeHeight' => "0",
'ResizeFillColor' => "" );
// WA_UploadResult1_1 End
// WA_UploadResult1 Params End
WA_DFP_SetupUploadStatusStruct("WA_UploadResult1");
if(isset($_POST["submit"]) || isset($_POST["submit_x"])){
WA_DFP_UploadFiles("WA_UploadResult1", "guide_file", "0", "", "false", $WA_UploadResult1_Params);
My submit button code is: <button type="submit" class="btn btn-mini btn-default btn-xs" id="submit" name="submit">
and I have used 'Button: submit pressed' as trigger.
My file input definition: <input name="guide_file" type="file" id="guide_file" onChange="" label="Upload file">
The php file is attached.
Regards
Willem
edit_list_ext.php
Upload forms need to have the <form> tag property set: enctype="multipart/form-data"
Willem
Thanks, Ray.
It works now. I did miss that one.
Regards
Willem
Willem
Databridge2 update of checkbox does not work
I am struggling to get my code to work to update a checkbox. The status of the checkbox is stored in the database field 'Good_exam1_p' as either 1 or a 0.
My form input code:
<input <?php if (!(strcmp($RS_Test2->getColumnVal("Good_exam1_p"),1))) {echo "checked=\"checked\"";} ?> name="answers_tick" type="checkbox" id="answers_tick" value="<?php echo $RS_Test2->getColumnVal("Good_exam1_p"); ?>">
The Databridge2 update code:
$UpdateQuery->bindColumn("Good_exam1_p", "c", "".((isset($_POST["answers_tick"]))?$_POST["answers_tick"]:"") ."", "WA_ZERO");
The php file was previously attached as edit_list_ext.php.
Your help will be appreciated.
WIllem
Willem
I did manage to get it working, so no need for a response.
Willem
