My WebAsssit apps seemed to have stopped working.
Thread began 8/01/2023 3:16 pm by Owen | Last modified 7/10/2024 1:26 pm by TroyD | 298 views | 5 replies |
Owen
Any time I try to use them the menus are empty, I'm not getting data management tools etc.
I am getting javascript error in Dreamweaver when loading DW at first. Its a general error and says the following JavaScript errors occurred but does not say what those are.
I have tried reinstalling Web Assist however the DMX Extension manager will no longer load WebAssist extension. Please advise next steps.
This is happening on 2 separate machines ... each is Windows 10 and has DW 2021 installed.
This should work to install the extension properly:
https://install.anastasiy.com/
PatriceWebAssist
I encountered this a few weeks ago with a non-WA extension (P7). I received this information.
The latest Adobe Creative Cloud update has introduced a file corruption issue in the Dreamweaver menus.xml and insertbar.xml files. This will cause extensions to not show in the Dreamweaver Insert menu and the Insert Panel. Hopefully Adobe will fix this soon.
You have a corruption in the underlying Dreamweaver files that now needs to be fixed.
1. Do NOT use the Anastasiy’s Extension Manager!
2. ONLY use the DMXzone Extension Manager.
3. Follow the instructions on the page link I sent. The Dreamweaver configuration folder is corrupt and needs to be replaced with a default configuration. The instructions here are very important, follow each step:
https://www.projectseven.com/products/ex-man/info.htm#cc-issue
First, be sure that you have re-started Dreamweaver after you renamed the configuration folder. Then shut Dreamweaver down.
In the DMXzone Extension Manager, if your extensions are listed as installed then you must first un-install each. Just click the X to the right of each extension. This will clear the extension database. Now you can install each one, one at a time.
Be sure that Dreamweaver is shut down during this operation.
~~HTH~~~
TroyD
Patrice,
I know this is an old thread but it seems to have the most current information that I can find when searching the subject.
I believe I need to remove and reinstall all of my extensions so that I can generate the most current library files. I usually do this every few months but have not in the past few months after reading that others have had issues. But I have no choice now and I wanted to check to see if there is a current known method for uninstall/reinstall? And if I encounter issues as mentioned by the op, is your solution still valid almost a year later? I know Adobe has done a couple of updates since then so I wanted see if I should be prepared for something different.
Thanks,
TroyD
PatriceWebAssist
I believe this is still accurate information.
TroyD
Thank you Patrice, I will give it a try.
TroyD
