Insert query fails to execute, cannot debug; gives error 500 page
Thread began 6/01/2023 1:16 pm by anonymous | Last modified 6/13/2023 7:17 pm by Ray Borduin | 131 views | 4 replies |
anonymous
I cannot insert the debug statement after the execute statement because the execute fails to execute.
$InsertQuery->saveInSession("");
echo 'error1';
$InsertQuery->execute();
echo 'error2';
The page is blank but says error1. I've been at this for 5 hours.....
Can you give me FTP access to debug it? It sounds like it could be a connection issue, or an issue with the server configuration.
anonymous
In PM
anonymous
Note i have multiple pages using the same webassist processes and they work fine.....
anonymous
is there any update on this?
I removed the insert query and re did it. No change. I have many other pages with this insert query and they work fine. Also the insert query to this same table on another page also fails. It seems like the issue is the particular table? I've never come across this. The table updates fine but will not take an insert.
And.... that just made me to right to MySQL Workbench and see if I could manually insert a new value and it fails. On export/import to a new server, it looks like two fields were flagged as non-null with no default value????? I cleared the non-null and added NULL as default value, and now everything works.
How in the name of apples to changes like this happen????? I haven't gone near that table...
