Registration Problem
Thread began 2/01/2023 1:04 pm by Kue Tae | Last modified 2/10/2023 3:06 pm by Ray Borduin | 71 views | 17 replies |
Kue Tae
After I tested the validation, I got this numbers ",2,4,5" without the quotation mark.
What is the next step?
Sounds like I may have left some debug code in one of the include files.... can you attach your page? I'd like to take a look.
Kue Tae
The Registration Problem attached files
After I tested the validation, I got this numbers ",2,4,5" without quotation mark around 23.2.1.
But I couldn't find out the exact page to generate the error indicating “,2,4,5” when I tested around 23.2.1.
Anyway, I post the attache files that I did tests around 23.2.1.
lkt_test_01.zip
lkt_test_02.zip
lkt_test_03.zip
I don't see what would be causing that.... Can you send me a url to reproduce and give me FTP access so I can debug it live?
Kue Tae
I think that I did not have a url and FTP access, but have a local connection using Xampp Control Panel, phpMyAdmin, Dreamweaver program.
So, I don't think I could understand what you are saying now. Sorry, I am new to know to create a Login page.
Can you show me a screenshot of the errors on the page?
I don't see the "2,4,5" you refer to.... where is that? That usually is a reference to the validation field that failed from lines 14-18 in your code.
2 is password length. It says it wasn't between 6-100 characters in length. 4 is the captcha and 5 is the simple question answer. I'm still confused where you saw those numbers.
Kue Tae
I posted the screenshot again.
Kue Tae
I remembered the reason why I couldn't find the page about the validation field.
Because I Iooked over the documentation about validation, I fixed the validation error.
as a result of that, it did not appear the error of ",2,4,5" any more.
After fixing the validation error, I had to meet another error saying "Invalid information, please check your entries and try again".
So, I manually input a user information to phpMyAdmin through Insert item and I tried to register the registration page,
but the page did not work to carry my input to database which stored the same information registered by Insert item.
Well it would be good to get the numbers back because it would tell you which fields it thinks are failing.
After line 5 add this:
<?php @session_start(); ?>
Then on your page somewhere you can see it add this:
echo("failed: " .ValidatedField('registration','registration'));
Let me know the results. If you still have issues, attach just the registration.php page in your reply so I can take a look.
