Webassist Extension Upgrade
Thread began 1/30/2023 8:56 am by anonymous | Last modified 1/30/2023 2:03 pm by Ray Borduin | 65 views | 9 replies |
anonymous
I am upgrading my PHP on the server to the latest version and I am getting alot of depreciated error messages (see below). The versions I have are:
authentication.php - 2.2
queryobj.php: 2.31
rsobj.php: 2.18
What are the latest versions and how do I get them? Thanks
The errors I get are:
Deprecated: Creation of dynamic property WA_MySQLi_Auth::$Action is deprecated in C:\Apache24\htdocs\webassist\mysqli\authentication.php on line 24
Deprecated: Creation of dynamic property WA_MySQLi_Auth::$AutoReturn is deprecated in C:\Apache24\htdocs\webassist\mysqli\authentication.php on line 25
Deprecated: Creation of dynamic property WA_MySQLi_Auth::$AutoLogin is deprecated in C:\Apache24\htdocs\webassist\mysqli\authentication.php on line 26
Deprecated: Creation of dynamic property WA_MySQLi_Auth::$AutoTrigger is deprecated in C:\Apache24\htdocs\webassist\mysqli\authentication.php on line 27
Deprecated: Creation of dynamic property WA_MySQLi_Auth::$CipherValues is deprecated in C:\Apache24\htdocs\webassist\mysqli\authentication.php on line 28
Deprecated: Creation of dynamic property WA_MySQLi_Auth::$Connection is deprecated in C:\Apache24\htdocs\webassist\mysqli\authentication.php on line 29
Deprecated: Creation of dynamic property WA_MySQLi_Auth::$CookieDomain is deprecated in C:\Apache24\htdocs\webassist\mysqli\authentication.php on line 30
Deprecated: Creation of dynamic property WA_MySQLi_Auth::$CookieExpires is deprecated in C:\Apache24\htdocs\webassist\mysqli\authentication.php on line 31
Deprecated: Creation of dynamic property WA_MySQLi_Auth::$CookieHTTPOnly is deprecated in C:\Apache24\htdocs\webassist\mysqli\authentication.php on line 32
Deprecated: Creation of dynamic property WA_MySQLi_Auth::$CookiePath is deprecated in C:\Apache24\htdocs\webassist\mysqli\authentication.php on line 33
Deprecated: Creation of dynamic property WA_MySQLi_Auth::$CookieSecure is deprecated in C:\Apache24\htdocs\webassist\mysqli\authentication.php on line 34
Deprecated: Creation of dynamic property WA_MySQLi_Auth::$CurrentPage is deprecated in C:\Apache24\htdocs\webassist\mysqli\authentication.php on line 35
Deprecated: Creation of dynamic property WA_MySQLi_Auth::$EncryptionAlgorithm is deprecated in C:\Apache24\htdocs\webassist\mysqli\authentication.php on line 36
Deprecated: Creation of dynamic property WA_MySQLi_Auth::$EncryptionKey is deprecated in C:\Apache24\htdocs\webassist\mysqli\authentication.php on line 37
Deprecated: Creation of dynamic property WA_MySQLi_Auth::$EncryptionMode is deprecated in C:\Apache24\htdocs\webassist\mysqli\authentication.php on line 38
Deprecated: Creation of dynamic property WA_MySQLi_Auth::$FailRedirect is deprecated in C:\Apache24\htdocs\webassist\mysqli\authentication.php on line 39
Deprecated: Creation of dynamic property WA_MySQLi_Auth::$FilterValues is deprecated in C:\Apache24\htdocs\webassist\mysqli\authentication.php on line 40
Deprecated: Creation of dynamic property WA_MySQLi_Auth::$HashValues is deprecated in C:\Apache24\htdocs\webassist\mysqli\authentication.php on line 41
Deprecated: Creation of dynamic property WA_MySQLi_Auth::$IsAuto is deprecated in C:\Apache24\htdocs\webassist\mysqli\authentication.php on line 42
Deprecated: Creation of dynamic property WA_MySQLi_Auth::$Name is deprecated in C:\Apache24\htdocs\webassist\mysqli\authentication.php on line 43
Deprecated: Creation of dynamic property WA_MySQLi_Auth::$ParamTypes is deprecated in C:\Apache24\htdocs\webassist\mysqli\authentication.php on line 44
Deprecated: Creation of dynamic property WA_MySQLi_Auth::$ParamValues is deprecated in C:\Apache24\htdocs\webassist\mysqli\authentication.php on line 45
Deprecated: Creation of dynamic property WA_MySQLi_Auth::$Redirect is deprecated in C:\Apache24\htdocs\webassist\mysqli\authentication.php on line 46
Deprecated: Creation of dynamic property WA_MySQLi_Auth::$RememberMe is deprecated in C:\Apache24\htdocs\webassist\mysqli\authentication.php on line 47
Deprecated: Creation of dynamic property WA_MySQLi_Auth::$Result is deprecated in C:\Apache24\htdocs\webassist\mysqli\authentication.php on line 48
Deprecated: Creation of dynamic property WA_MySQLi_Auth::$SaveLogin is deprecated in C:\Apache24\htdocs\webassist\mysqli\authentication.php on line 49
Deprecated: Creation of dynamic property WA_MySQLi_Auth::$Statement is deprecated in C:\Apache24\htdocs\webassist\mysqli\authentication.php on line 50
Deprecated: Creation of dynamic property WA_MySQLi_Auth::$StoreValues is deprecated in C:\Apache24\htdocs\webassist\mysqli\authentication.php on line 51
Deprecated: Creation of dynamic property WA_MySQLi_Auth::$SuccessRedirect is deprecated in C:\Apache24\htdocs\webassist\mysqli\authentication.php on line 52
Deprecated: Creation of dynamic property WA_MySQLi_Auth::$Table is deprecated in C:\Apache24\htdocs\webassist\mysqli\authentication.php on line 53
Deprecated: Creation of dynamic property WA_MySQLi_Auth::$Trigger is deprecated in C:\Apache24\htdocs\webassist\mysqli\authentication.php on line 54
Fatal error: Uncaught TypeError: sizeof(): Argument #1 ($value) must be of type Countable|array, string given in C:\Apache24\htdocs\webassist\mysqli\authentication.php:246 Stack trace: #0 C:\Apache24\htdocs\family_portal\annual_forms.php(21): WA_MySQLi_Auth->execute() #1 {main} thrown in C:\Apache24\htdocs\webassist\mysqli\authentication.php on line 246
If you reinstall databridge, the code has been updated to fix this issue. You would have to reapply a recordset, authenticate, and insert or update server behavior to get the associated files updated so you can upload them.
anonymous
How do I download the DataBridge file? When I login it doesn't show my downloads since it has been so long.
Do you have your serial number? I could look up your account if you post it in the private area of a reply.
anonymous
Here is the number
I've put the email address associated with that order in the private area. You can log in with that to download the latest version.
anonymous
LWat85283715
I was able to download the file but, now it doesn't open. Is there a specific extension manager that I need to use? I have downloaded DMX Zone Manager.
DMXZone's should work... You could also try: https://install.anastasiy.com/
LWat85283715
That worked! Thanks so much!
