Hello, I work with Dreamweaver and have MySQLi Server Behaviors from webassist as an add-on module. Now I have a question: PHP 7.4 will soon be deactivated at my hosting provider. It seems that webassist's scripts are not compatible with PHP 8.1... w
Thread began 11/10/2022 2:09 am by anonymous | Last modified 11/30/2022 10:17 am by Ray Borduin | 247 views | 16 replies |
anonymous
Hello, I work with Dreamweaver and have MySQLi Server Behaviors from webassist as an add-on module. Now I have a question: PHP 7.4 will soon be deactivated at my hosting provider. It seems that webassist's scripts are not compatible with PHP 8.1... what ca
I switched my hosting provider from php7.4 to php 8.1 and my customer's news page was no longer displayed - it was a white page
The current versions of webassist scripts are all compatible with php 8
anonymous
empty/white page after switching to PHP 8.1
Hello, unfortunately it shows an empty/white page after switching to PHP 8.1... what could be the reason?
http://www.weltladen-koengen.de/aktuelles.php
Best regards Andrea
Add this to the top of the page:
ini_set("display_errors",1);
That should make the page show the error message and could give a good clue on how to solve it.
anonymous
PHP 7.4 to PHP 8.1
Hello,
Thank you for your response. I added the code to the page - it's still blank. On Monday the hosting provider switched from PHP 7.4 to PHP 8.1 - since then the page has not been displayed anymore. On Sunday everything was still o.k. It must be because of the php conversion.
Greetings Andrea Halm
If you give me FTP access in the private area of a reply, then I can debug the page and try to figure out what is wrong.
anonymous
I'd need FTP access to debug it. I don't see any issue with the page.
anonymous
Hello, as this is a client's site I cannot give you FTP access. The problem is that since the switch to php8 it doesn't show the page with the php script anymore: http://www.weltladen-koengen.de/aktuelles.php ... I've now switched the page back to html and have to do it like this http://www.weltladen-koengen.de/aktuelles.html Thanks anyway for your answers. Greetings Andrea Halm
If you call then I can do screen sharing with you to help you debug it. I have to narrow down the line of code and exact error in order to fix it and I need access to the file to do that. There is very little that could be wrong in that file. I'm thinking it has to be the connection to the database that is wrong, but I can't say for sure without active debugging.
