Dreamweaver 2021
Thread began 11/04/2022 11:16 am by James | Last modified 11/10/2022 12:35 pm by Ray Borduin | 148 views | 3 replies |
James
Dreamweaver 2021
I just purchased the Mysqli Server Behaviors extension doesn't seem to be working with DW 2021. It shows WebAssist up in the Toolbar, but when I click on Database-> Model Database (which is the only option). The program does nothing. Is this extension not compatible with DW 2021?
It is compatible. It may not have installed properly or your site may not be configured properly.
If you want to give me a call I can look into it with you in a screen sharing session.
James
Dynamic Text or
Thanks Ray, I did just remove all instances of the install then reinstalled the extension and it started working. However after connecting to a DB and creating a recordset. Then if I try to just simply add dynamic text or do a repeat region, etc... I keep getting the error "While executing applyServerBehavior in DynamicTex.htm, JavaScript error occurred." OR the error may be "While executing applyServerBehavior in MySQLiRepeatedRegion.htm, JavaScript error occurred." It just depends on what I'm trying to do. Is there any type of setting I might have wrong to why I can't use these simple functions of the extension?
You could try clearing out your winfilecache.dat file, or it could be an issue with the page itself causing problems. If you give me a call I can do screen sharing with you and help you figure it out.
