installation
Thread began 7/20/2022 9:25 am by Aarati | Last modified 7/25/2022 12:24 pm by Ray Borduin | 222 views | 7 replies |
Aarati
installation
How do I install Ecart? I'm using Dreamweaver CC 21.3. Thanks!
Adobe dropped support for the extension manager. There are a few free third-party options like:
https://www.dmxzone.com/go/22670/dmxzone-extension-manager-for-dreamweaver/
or
https://install.anastasiy.com/
Aarati
Thanks. Where do I enter the serial no.?
Once it is installed it will ask you to enter the serial number the first time it is used in Dreamweaver.
Aarati
Do your products work together with Project 7 Dw extensions? I'm trying to install them while Ecart is installed, and they are not appearing.
Also, I'm trying to use Ecart and the dropdown options are grayed out.
Yes they work together. You need to have a .php page open and a testing server properly defined in Dreamweaver before you can use eCart. Try updating your Dreamwever site definition and defining a testing server and then create a .php page and your extension options should become enabled. Let me know if that doesn't work and I can help figure out what else might be going wrong.
Aarati
Hi, I'm trying to access this link but it doesn't appear to work. Can you tell me where to find this tutorial?
Adobe removed the Databases panel from Dreamweaver CC so if you are using Dreamweaver CC or newer, you will need to first follow this tutorial.
Thanks,
This step and tutorial isn't necessary anymore. We automatically include the Database functionality in all of our extensions, so you only have to install our extension and the database panel is automatically included.
