Having issue with PHP Version 8.0.14
Thread began 6/26/2022 4:22 am by anonymous | Last modified 6/27/2022 12:21 pm by Ray Borduin | 94 views | 1 replies |
anonymous
Getting the following error with this version of php:
Fatal error: Uncaught TypeError: mysqli_fetch_fields(): Argument #1 ($result) must be of type mysqli_result, bool given in....webassist/mysqli/rsobj.php:226 Stack trace: #0
Have verified that code base is working on an older version of php. The versions of your scripts I am using is:
rsobj.php // version 2.49
queryobj.php // version 2.31
Help! Thank you in advance.
Update your rsobj.php file and update the line:
$this->Prepared = true;
$this->Prepared = false;
That could fix the problem if you are running into a known bug in mysql when querying stored procedures and views.
If that doesn't work, then you may have an issue with your connection or sql statement itself.
