How to implement AESENCRYPT() on insert and update Mysqli sentences with WebAssist?
I am trying to insert data using the Mysql function AESENCRYPT, but can not be done with WebAssist
In order to take advantage of advanced mySQL functions like that you would need to use the Server Behavior: "mySQLi"-> "Data Management"-> "MySQLi Execute Query"
Then you can write a complex insert to use any MySQL functions you might need.
