SecurityAssist registration page not validating correctly
Hello,
I used SecurityAssist to Create Security Pages with the wizard. A few strange things happened with the registration page:
1) The post variables were not set correctly for two of the fields in the Insert Record behavior. This was easy enough to fix by clicking on the behavior in the panel and correctly setting the bindings manually.
2) The bigger issue is that the form validation is not working correctly. When I attempt to register twice with the same email address and/or scout name (which is not allowed), it still redirects to my success page without any warnings or notes even though it does not enter data into the database. Right now I have it hooked up to a simple page that echos the email, scout name and hometown by taking the session variable that should be set by the registration form and using it to create a recordset of that data. When this failure happens, I get a message that I have an error in my SQL syntax because I am assuming that the session variable has been unset.
I am attaching the php file that was generated for the registration page. Any help would be greatly appreciated!
Thank you!
