Time Field In Form
Thread began 6/16/2021 10:31 am by Jared | Last modified 6/21/2021 1:57 pm by Ray Borduin | 287 views | 5 replies |
Jared
Time Field In Form
I am trying to add a time field to a form. Everything works until I fill out the form. Once I enter a time (10:00 AM), it immediately gives the error "Please Enter A Value" even though I have put a full value in the field. Thank you for your time and assistance.
Please attach a copy of the page.
Jared
Here is the file.
add_event.php
Jared
Ray, Here is the original file that I created with webassist before I began to try to edit it to work in my current site. It may be a better file to try to find the issue since there is less changes to the code. I apologize! I should have sent this file to you first.
test.php
I had to update the jquery.h5validate.js file. I've attached the updated version. I've also updated Databridge, so if you reinstall the updated file will be used the next time you create a form.
Jared
Ray, Thank you once again! I really appreciate your help. As always, the best customer service! Thank you!
