Submit records in multiple rows not working
Thread began 5/24/2021 5:21 pm by Michael | Last modified 5/27/2021 7:45 pm by Ray Borduin | 129 views | 9 replies |
Michael
Hello Ray,
Please I kindly need your help on this. I have a form with 3 different array fields prt_id, mds_id and ptid but when I submit the form, only one record in prt_id is submitted and one row only instead of 9 six rows as I selected 3 different options in the 3 dropdown select fields
What am I not doing well looking at my code below:
if ($_SERVER["REQUEST_METHOD"] === "POST") {
$InsertQuery = new WA_MySQLi_Query($FRCDB);
$InsertQuery->Action = "insert";
$InsertQuery->Table = "verification";
$InsertQuery->bindColumn("prt_id", "i", "".($_POST["prt_id"][$x]) ."", "WA_DEFAULT");
$InsertQuery->bindColumn("mds_id", "i", "".($_POST["mds_id"][$x]) ."", "WA_DEFAULT");
$InsertQuery->bindColumn("aimsobj", "s", "".((isset($_POST["aimsobj"]))?$_POST["aimsobj"]:"") ."", "WA_DEFAULT");
$InsertQuery->bindColumn("ptid", "i", "".($_POST["ptid"][$x]) ."", "WA_DEFAULT");
$InsertQuery->bindColumn("phyinspctn", "s", "".((isset($_POST["phyinspctn"]))?$_POST["phyinspctn"]:"") ."", "WA_DEFAULT");
$InsertQuery->bindColumn("mdamtng", "s", "".((isset($_POST["mdamtng"]))?$_POST["mdamtng"]:"") ."", "WA_DEFAULT");
$InsertQuery->bindColumn("contctmtng", "s", "".((isset($_POST["contctmtng"]))?$_POST["contctmtng"]:"") ."", "WA_DEFAULT");
$InsertQuery->bindColumn("consntmtng", "s", "".((isset($_POST["consntmtng"]))?$_POST["consntmtng"]:"") ."", "WA_DEFAULT");
$InsertQuery->bindColumn("others", "s", "".((isset($_POST["others"]))?$_POST["others"]:"") ."", "WA_DEFAULT");
$InsertQuery->bindColumn("recomnds", "s", "".((isset($_POST["recomnds"]))?$_POST["recomnds"]:"") ."", "WA_DEFAULT");
$InsertQuery->bindColumn("addedby", "s", "".((isset($_POST["addedby"]))?$_POST["addedby"]:"") ."", "WA_DEFAULT");
$InsertQuery->saveInSession("pjv_id");
$InsertQuery->execute();
$InsertGoTo = "verification";
if (function_exists("rel2abs")) $InsertGoTo = $InsertGoTo?rel2abs($InsertGoTo,dirname(__FILE__)):"";
$InsertQuery->redirect($InsertGoTo);
Thank you
Your insert redirect is going to cause the page to redirect after the first insert. You would have to remove the redirect to allow all of the inserts to take place. If you want to loop on multiple arrays, you would need multiple FOR loops as well. 3 different options with 3 different options would insert 27 rows if you looped on all 3.
Michael
Thank you so much.
By removing the redirect, it means I will have to remove the *$InsertGoTo = "verification";*
OK let me try it out
Michael
Thank you so much Ray. Your idea worked. I removed the redirect and the records were inserted based on the number of prt_id records. However, that gave me a different route to the project. I changed
$InsertQuery->bindColumn("mda", "s", "".((isset($_POST["mda"]))?implode(",",$_POST["mda"]):"") ."", "WA_DEFAULT");
$InsertQuery->bindColumn("projectteam", "s", "".((isset($_POST["projectteam"]))?implode(",",$_POST["projectteam"]):"") ."", "WA_DEFAULT");
So that the entries will reply on only one multiple row entries which is the prt_id records.
I am so grateful
Michael
2 Things Ray,
1. Please how do I redirect after insertion. My code is without this lines now
2. I am getting this error "Notice: Undefined index: prt_id in C:\wamp64\www\frcapp\add_project_verification.php on line 46". Please see attached image, how do I resolve it please. I have done my best to remove it but its not going of
Thank you
Please attach the page with the error. I'd want to look at line 46 (and probably the lines above it) to see what is wrong.
Michael
Please find attached the file with error on line 46
Michael
Hi Ray, please I am still waiting for your response on this. I had earlier sent the page with the error for your viewing.
Thank you
Just add the redirect manually below the insert loop like:
header("location: redirectpage.php");
  die();
Michael
  die();
Thank you sir.
I tried it out and it worked
