insert of multiple dropdown option into one row
Thread began 4/28/2021 7:50 pm by Michael | Last modified 4/29/2021 4:55 pm by Ray Borduin | 221 views | 2 replies |
Michael
Please I am trying to insert multiple dropdown selection options into one row and not multiple rows but its not working out.
The field is a state field. So when I select multiple fields only one is selected.
Kindly assist on how I can resolve it.
Attached is the raw file
Double click on your MySQLi Insert Server Behavior, update the Column Bindings tab and change state column binding. click the lightning bolt and select: "state[] (csv)" from the form.
That should insert a comma separated list of states selected into the database.
Michael
Thank you so much for your kind response.
While waiting for your response I took time to check other related questions and got an idea from one of them and then change my state code line
from
$InsertQuery->bindColumn("state", "s", "".((isset($_POST["state"]))?$_POST["state"]:"") ."", "WA_DEFAULT");
to
$InsertQuery->bindColumn("state", "s", "".((isset($_POST["state"]))?implode(", ",$_POST["state"]):"") ."", "WA_DEFAULT");
and that solve the problem.
Thank you so much
