Web development tutorial, "Create a search page that displays filtered results" error.
Web development tutorial, "Create a search page that displays filtered results" I was able to follow until the stage when I was required to “… create a repeated region to repeat the results so that more than the first search result is displayed.”
At that point, when I chose Repeated Region from the Server Behaviours panel, I got message, “Before using this server behaviour, please create a Recordset,” despite that I had created previously Recordset (rsItems) as you can see from the attached screen shot. For some reason, the system does not recognise that there is a recordset on the page. So, I was not able to continue.
Also, when I click search on the search page, I get “Fatal error: Uncaught Error: Call to undefined function WADS_stripCurrency() in C:\xampp\htdocs\SearchWizard\Results.php:8 Stack trace: #0 {main} thrown in C:\xampp\htdocs\SearchWizard\Results.php on line 8.”
What is the reason for these messages, and how to solve these problems?
