How to create result page with DataAssist Search Wizard?
I tried to use DataAssist Search Wizard, but I was not able to understand the purpose of it. It does not create result page. How should I use DataAssist Search Wizard and create result page?
You need to create the results page and apply the wizard from that page. Then it creates the search page for the results page you are on.
The results page is just a recordset with the fields displayed in a repeated region.
