SecurityAssist Keeps Giving Errors
I am trying to create login pages using SecurityAssist. I have never had any problems in the past; however, I am now getting many errors on the login page. Can you give me some direction how to troubleshoot. Thanks for your help.
Errors:
Notice: Undefined variable: WA_Auth_Separator in /Applications/XAMPP/xamppfiles/htdocs/api/admin/login.php on line 67
Warning: explode(): Empty delimiter in /Applications/XAMPP/xamppfiles/htdocs/api/admin/login.php on line 67
Notice: Undefined variable: WA_Auth_Separator in /Applications/XAMPP/xamppfiles/htdocs/api/admin/login.php on line 68
Warning: explode(): Empty delimiter in /Applications/XAMPP/xamppfiles/htdocs/api/admin/login.php on line 68
Notice: Undefined variable: WA_Auth_Separator in /Applications/XAMPP/xamppfiles/htdocs/api/admin/login.php on line 69
Warning: explode(): Empty delimiter in /Applications/XAMPP/xamppfiles/htdocs/api/admin/login.php on line 69
Notice: Undefined variable: WA_Auth_Separator in /Applications/XAMPP/xamppfiles/htdocs/api/admin/login.php on line 70
Warning: explode(): Empty delimiter in /Applications/XAMPP/xamppfiles/htdocs/api/admin/login.php on line 70
Notice: Undefined variable: WA_Auth_Separator in /Applications/XAMPP/xamppfiles/htdocs/api/admin/login.php on line 71
Warning: explode(): Empty delimiter in /Applications/XAMPP/xamppfiles/htdocs/api/admin/login.php on line 71
Warning: implode(): Invalid arguments passed in /Applications/XAMPP/xamppfiles/htdocs/api/webassist/security_assist/helper_php.php on line 32
You have an error in your SQL syntax; check the manual that corresponds to your MySQL server version for the right syntax to use near '' at line 1
