Page is not redirected
Thread began 2/21/2021 1:19 pm by Jeff | Last modified 2/25/2021 12:46 pm by Ray Borduin | 548 views | 10 replies |
Jeff
Hi Ray,
I have created a page restriction and redirecting it to another page, it works on the localhost but doesn't show up on on webserver.
session on the webserver works well.
http://nyumbasaccos.co.tz/portal/session_show.php
Please help
What do you mean by "doesn't show up"? Usually this means you didn't upload all of the necessary files to the live server.
Jeff
Please note every file is uploaded to server
I get an "invalid username or password" message.
Is that what you are getting and need help with?
Jeff
Sorry the Password I gave was incorrect
What is it that isn't working? I log in and see the profile page. I need steps to reproduce the issue you want me to help with.
Jeff
Let me explain how it works
I'd need FTP access to debug this.
Usually a blank page means a missing file.
You could try adding this to the top of the page:
ini_set("display_errors",1);
That will sometimes have it display an error instead of a blank page that you can use to fix the problem.
Jeff
FTP Account
Blank lines in .php will prevent redirects from working.
On mycontrshr.php you have blank lines on line 11 and 17. Delete those and the redirects should start working.
