Errors Trying to add or update products in our database
Thread began 12/07/2020 10:42 am by Charles | Last modified 12/08/2020 12:02 pm by Ray Borduin | 203 views | 2 replies |
Charles
I have previously working Admin tools built through WA that giving me the following errors-
When I try to ADD a new product (products_update.php): "Field 'Category' doesn't have a default value"
When I try to UPDATE a product (products_insert.php): "Incorrect integer value: 'Array' for column `gsc_products`.`products`.`Category_ID` at row 1"
I have double-checked the database and I am able to manually edit and add products directly in the DB as well as use the Admin tools to edit other tables like categories and locations - so the DB is not corrupt
Any direction you can give would be appreciated
Charles
See below..
We handled this in a screen sharing session. The page or database must have been updated because the column types and default values for database columns were out of sync. They are fixed now, so let me know if you need help with anything else.
