How can I share Recordsets from page to page?
Is there any way to use an include file? I must be missing something, because I can't drag and drop.
You should be able to copy and paste from the Server Behaviors window using Ctrl+C and Ctrl+V
So, the recordsets need to be in the file itself, not in a separate file that is included?
You can add an include file or plugin to share it from page to page as well.
Use: Insert->PHP->Require
or: WebAssist->Framework Builder->Plugin->Insert Plugin to Page
