Insert Multiple Record Issue
I have the form that queries the database and makes a copy of all the records in the query and then inserts them into the database as a new record. For some reason, I can't get the page to work and I see no error message. Any thoughts?
Here is the code:
$rollover_year = $_GET['rollover_year'];
if (isset($_POST["submit"]) || isset($_POST["submit_x"])) {
$InsertQuery = new WA_MySQLi_Query($course_catalog);
$InsertQuery->Action = "insert";
$InsertQuery->Table = "courses";
$InsertQuery->bindColumn("course_number", "s", "".((isset($_POST["course_number"]))?implode(", ",$_POST["course_number"]):"") ."", "WA_DEFAULT");
$InsertQuery->bindColumn("course_title", "s", "".((isset($_POST["course_title"]))?implode(", ",$_POST["course_title"]):"") ."", "WA_DEFAULT");
$InsertQuery->bindColumn("stateID", "s", "".((isset($_POST["stateID"]))?implode(", ",$_POST["stateID"]):"") ."", "WA_DEFAULT");
$InsertQuery->bindColumn("departmentID", "i", "".((isset($_POST["departmentID"]))?implode(", ",$_POST["departmentID"]):"") ."", "WA_DEFAULT");
$InsertQuery->bindColumn("status", "s", "".((isset($_POST["status"]))?implode(", ",$_POST["status"]):"") ."", "WA_DEFAULT");
$InsertQuery->bindColumn("description", "s", "".((isset($_POST["description"]))?implode(", ",$_POST["description"]):"") ."", "WA_DEFAULT");
$InsertQuery->bindColumn("notes", "s", "".((isset($_POST["notes"]))?implode(", ",$_POST["notes"]):"") ."", "WA_DEFAULT");
$InsertQuery->bindColumn("core_elective", "s", "".((isset($_POST["core_elective"]))?implode(", ",$_POST["core_elective"]):"") ."", "WA_DEFAULT");
$InsertQuery->bindColumn("year", "s", "".((isset($_POST["year"]))?implode(", ",$_POST["year"]):"") ."", "WA_DEFAULT");
$InsertQuery->bindColumn("subcategory", "s", "".((isset($_POST["subcategory"]))?implode(", ",$_POST["subcategory"]):"") ."", "WA_DEFAULT");
$InsertQuery->bindColumn("grade_level", "s", "".((isset($_POST["grade_level"]))?implode(", ",$_POST["grade_level"]):"") ."", "WA_DEFAULT");
$InsertQuery->bindColumn("pre_reqs", "s", "".((isset($_POST["pre_reqs"]))?implode(", ",$_POST["pre_reqs"]):"") ."", "WA_DEFAULT");
$InsertQuery->bindColumn("credit_assignment", "s", "".((isset($_POST["credit_assignment"]))?implode(", ",$_POST["credit_assignment"]):"") ."", "WA_DEFAULT");
$InsertQuery->bindColumn("course_designation", "s", "".((isset($_POST["course_designation"]))?implode(", ",$_POST["course_designation"]):"") ."", "WA_DEFAULT");
$InsertQuery->bindColumn("modified_date", "t", "".((isset($_POST["modified_date"]))?implode(", ",$_POST["modified_date"]):"") ."", "WA_DEFAULT");
$InsertQuery->saveInSession("");
$InsertQuery->execute();
$InsertGoTo = "home.php";
if (function_exists("rel2abs")) $InsertGoTo = $InsertGoTo?rel2abs($InsertGoTo,dirname(__FILE__)):"";
$InsertQuery->redirect($InsertGoTo);
<form id="form1" name="form1" method="post">
$wa_startindex = 0;
while(!$rollover_selection->atEnd()) {
$wa_startindex = $rollover_selection->Index;
<input type="hidden" name="status[]" id="status" value="Proposed">
<input type="hidden" name="course_number[]" id="course_number" value="<?php echo($rollover_selection->getColumnVal("course_number")); ?>">
<input type="hidden" name="description[]" id="description" value="<?php echo($rollover_selection->getColumnVal("description")); ?>">
<input type="hidden" name="departmentID[]" id="departmentID" value="<?php echo($rollover_selection->getColumnVal("departmentID")); ?>">
<input type="hidden" name="stateID[]" id="stateID" value="<?php echo($rollover_selection->getColumnVal("stateID")); ?>">
<input type="hidden" name="course_designation[]" id="course_designation" value="<?php echo($rollover_selection->getColumnVal("course_designation")); ?>">
<input type="hidden" name="course_title[]" id="course_title" value="<?php echo($rollover_selection->getColumnVal("course_title")); ?>">
<input type="hidden" name="credit_assignment[]" id="credit_assignment" value="<?php echo($rollover_selection->getColumnVal("credit_assignment")); ?>">
<input type="hidden" name="grade_level[]" id="grade_level" value="<?php echo($rollover_selection->getColumnVal("grade_level")); ?>">
<input type="hidden" name="pre_reqs[]" id="pre_reqs" value="<?php echo($rollover_selection->getColumnVal("pre_reqs")); ?>">
<input type="hidden" name="subcategory[]" id="subcategory" value="<?php echo($rollover_selection->getColumnVal("subcategory")); ?>">
<input type="hidden" name="core_elective[]" id="core_elective" value="<?php echo($rollover_selection->getColumnVal("core_elective")); ?>">
<input type="hidden" name="year[]" id="year" value="<?php echo $_GET['rollover_year']; ?>">
<input type="hidden" name="modified_date[]" id="modified_date" value="<?php echo($rollover_selection->getColumnVal("modified_date")); ?>">
<input type="hidden" name="notes[]" id="notes" value="<?php echo($rollover_selection->getColumnVal("notes")); ?>">
$rollover_selection->moveNext();
$rollover_selection->moveFirst(); //return RS to first record
unset($wa_startindex);
unset($wa_repeatcount);
<br><button type="submit" class="btn-lg btn-info" name="submit" id="submit">Yes, Rollover Now!</button>
</form>
